Results 1 to 6 of 6
Thread: OCZ Cryo-Z 3 Beeps No Boot
    Jul 2007
    Arizona - USA
    Exclamation OCZ Cryo-Z 3 Beeps No Boot
    Hi I already emailed Ryder about this issue but I decided to post here as well so others with the same problem can reach this info someday.
    I decided to power Cryo-Z unit as stand alone (without connections to the mobo pwr-sw jumper) because the unit is not turning the motherboard on when it hit's 30oC (this issue is under OCZ tech support for solution).
    I'm working on my new build as you can see in my Worklog (signature) so I have to get some things going until I wait for more parts to arrive.
    So today I got this new switch to be the Cryo-Z starter and I was planing to drill a hole in the 5 1/4 bays to start up the Cryo and then I can press the power sw to start up the PC manually after Cryo-Z gets below -25oC.
    Problem is after I decided to test if this is gonna work I was surprised when I got this:
    What is wrong?
    //RETIRED-o00o--°(_)°--o00o-OVERCLOCKER//
    Jul 2007
    Arizona - USA
    Well today I decided to hook the Cryo-Z on the motherboard again... It worked fine again (only works if all the red/white cable is pluged IN the mobo)... But it won't power the mobo on after it hits -30oC.
    So the unit powered on fine but how am I supposed to power the motherboard independently if the Cryo-Z need to be pluged-in the ATX_SW jumper in the mobo to work? My initial idea to use the unit until OCZ fixes this problem was to make an independent plug for the Cryo-Z and the case pwr on swithch would go to the mobo atx sw jumper... But now Cryo-Z requires that jumper should I make a dual output from that jumper (on going to the case swich and the other to the Cryo)? Will this work?
    Ryder you told me something about power the Cryo-Z independently how do I accomplish this?
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    I posted some notes to this problem, my work around was to rip out the controller and hard wire the compressor to the switch but you lose the display unless you have the parts to rewire one on.
    I had problems with 790i not firing up when it hit temp even with the correct wires attached.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Jul 2007
    Arizona - USA
    Quote Originally Posted by FUGGER View Post
    Thanks for your inputs FUGGER I saw your notes on that.
    I was thinking of making a little split connection on the mobo PWR-SW jumper (two heads coming out of that jumper) one would go to the case and the other to the Cryo red/white wires just for it to start (sensing that was connected to the board).
    Then I would power the Cryo and wait till -25oC an then hit th case pwr sw to power up the mobo.
    Jul 2007
    Arizona - USA
    Solution for half of the problem.
    A note for you guys.
    I came up with this idea yesterday and took my soldering iron out of the closet to see if it would work:
    Patent Pending I will cut it shorter and ad some sleeving to make it look nicer.
    I connected this split on the mobo and 1 pair of legs to the Cryo-Z and the other to the case switch.
    With that I was able to turn the Cryo-Z ON successfully and then at about -25oC I turn the pc on hitting the case switch
    So until OCZ RMA's my Cooler Express Control board I will use this handy solution.
    Jun 2004
    plan3t 3@rth
    Quote Originally Posted by Jor3lBR View Post
    nice job.how is the unit working for u? whats 24/7(stable) cpu and temps at..?
    Stacker830 Watercooled
    windows7 ultimate 64 bit!!!
    heatkiller(rev3) on 2500k@ 4.5ghz 1.35v,8 gigs 2133 ripjaws 1.5v
    Swiftech Mcp-655,1/2in tygon,13x120 sunnons on junk ps,
    (2)triple 120mm rads,Biostar TP67XE(rev 5.2)
    150 gig velicraptor (stable drive) ssds r still buggy!!
    xfi-xtrememusic,klipsch ultras, sen hd-595s
    Evga Hydro gtX 590,co0lermaster-1250 watt,
    24" Sony fw-900 black ops at @ 2304x1440 85hz/85fps SOLID
    G@m3r 4 L1Fe!!
    http://s76.photobucket.com/albums/j1...0VIEW%20ALL--/
    3dmark 11 http://3dmark.com/3dm11/1102387
