Results 1 to 9 of 9
Thread: 3:5 divider on X38/P35/X48/P45 is broken, is 2:3 in reality on 400 strap
    Admin
    Dec 2003
    Hillsboro, OR
    Exclamation 3:5 divider on X38/P35/X48/P45 is broken, is 2:3 in reality on 400 strap
    Needs a thread of it's own for a bit, IMHO
    Quote Originally Posted by hicookie View Post
    Hi, Bros,
    3:5 400mhz Strap of all intel chipset is incorrect. due to chipset divider limit
    for other strap (200/266/333) 3:5 runs correct ratio & frequency.
    3:5 400 Strap should be 2:3, not 3:5
    if you are running 600Fsb and chosen divider of 3:5 400 Strap
    Frequency of memory is 900mhz(DDR3-1800), if 650FSB,mem is 975mhz
    Hicookie
    uncore challenged...
    Feb 2006
    ontari-ho (canada)
    thanks Gautam, we both knew that's what it was...confirmation is nice though.
    i don't quote in my signature, but best WR ever...
    Quote Originally Posted by Jor3lBR View Post
    It holds the current WR for the least vcore required to run 4500Mhz stable (1.32vcore)
    i can't even make that shyt up ^^^
    Memory Addict
    Aug 2002
    Brisbane, Australia
    has same on DFI UT X48-T3RS with 400/1333 at first DFI said it's incorrect and should be 400/1200 but then subsequently it is 400/1333 http://i4memory.com/showthread.php?t=6657
    could explain low performance on 400/1333 http://i4memory.com/91204-post9.html
    Xtreme Cruncher
    Jul 2003
    Finland, Eura
    This should be also on news section.
    We do need someone from Intel to comment this.
    http://mato78.com - Finnish PC Hardware news & reviews
    BulldogPO @ Twitter
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Just means I have more room to overclock above 600FSB and the "3:5" divider
    D-m.o.s.t
    Jul 2005
    The Netherlands
    More room gomeler but worse performance.
    ran 620 3:5 400 strap (1033 memory) but notish no difference in performance over 2:3 on auto strap.(930 memory)
    strange thing is i need more voltage on the memory to do this though.
    May 2006
    Belgium
    Saw exactly this on the Asus P5Q3 in my latest memory (OCZ Flex II) review. Nice to see it confirmed.
    "The light at the end of the tunnel is the headlight of an oncoming train" (Murphy)
    Reviewing for Madshrimps
    Moderator
    Nov 2006
    thanks guantum i confirm it
    this is my test
    boot@600
    strap :400
    dram freq : 1800
    and cpuz in win says
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
    Aug 2007
    Belgium
    This is on Evolution X48:
    cpu-z 1.45 reads it correctly.
    Same situation on X48 p5e3 Premium
