Results 1 to 9 of 9
Thread: Very interesting find
    Jun 2007
    Wayne NJ
    Hi guys.
    did some testing on vista64 bit.
    With bios only adjustments my maximum stable clock speed was 3.1Ghz vs. 3.3Ghz on Win Xp32 Bit.
    As expected.
    I still run the DFI M2RS with SB600.
    Somehow i discovered that the CPU VDDC setting in AOD does improve my oc significantly !!!!
    My system would normally crash immediately with CPU VID at max (1.45V) at 3.2Ghz.
    I was able to hit 3.3Ghz almost stable and as it seems 3.248Ghz stable with slightly reference clock oc with NB at 2.2Ghz.
    This is really almost unbelievable because its impossible to get this oc with bios only settings.
    So CPU VDDC does MUCH to your oc stability !!!
    I wish AOD would not show so many bugs because otherwise it would be usefull everyday
    Here is a screenshot of AOD and Cinebench results
ID:	83724   Click image for larger version.
    AMD Phenom II 1090T @ 4GHz Asus Crosshair IV
    HD6970
    LSI Megaraid 9260-4i 4xMomentus XT
    OCZ Vertex 3@SB850
    8 gig Patriot Viper 7-7-7-24 T1
    Swiftech Watercooling
    Filco Majestouch 2
    Zowie EC1
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    Yeah. On my K9A2 the only adjustment I ever make is vDDC. The VID setting never even seemed to do anything (ie, non-functional) on it.
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
    Banned
    Jun 2008
    Somewhere Up to my Ears in Ye Yo
    mmmm
    i personaly hate AOD, i think because whenever i use it on my current rig it fails, or corupts my bios.
    funny thing the other day, i was showing a mate the software (new release) and he was messing about with it,(but hadnt made any changes)
    he moved the HT ref clock to 203 and hit apply...the rig went into this high pitched squeel and locked up, the speakers where way up, and he S**T himself.
    funny
    Jun 2007
    Wayne NJ
    Its not VDDC alone !!!
    You have to increase both VID and VDDC in a certain ratio.
    Currently have mine VDDC little higher or same as VID but had to go safe running at 3.2GHz on vista 64bit.
    HD6970
    OCZ Vertex 3@SB850
    Filco Majestouch 2
    Zowie EC1
    Jul 2005
    mmmm
    But you don't hate your board which is causing the issue? Funny.
    Jun 2007
    Wayne NJ
    Yes i hate it but have no other choice until the asus comes out....
    HD6970
    OCZ Vertex 3@SB850
    Filco Majestouch 2
    Zowie EC1
    Mar 2008
    New Jersey, Center of the Universe
    Quote Originally Posted by MrMojoZ View Post
    Nope, I hate AOD also, and not my board. It just sucks. I've had LOTS of boards that work with AOD (Asus M3A32-MVP, MSI K9A2 Platinum, DFI 790FX-M2R, Gigabyte MA780G-S2H, Gigabyte MA780-DS3H) and it sucks on ALL of them. I stopped using it on everything except the DFI, as it causes the LEAST damage there. The 780G boards get totally mutilated by it.
    It reminds me of the severely brain damaged Nvidia control panel in the early days, when it would destroy the BIOS of the mainboard and you had to either RMA or reload BIOS.
    There are TERRIBLE mismatches between AOD and mainboard terminology, as well as massive inaccuracies between things like voltage, memory settings, CPU settings, North Bridge and PCIe settings.
    I can set up my DFI 790FX board to be 100% reliable at say, 3Ghz in BIOS, then load AOD after boot, and voila', the stability is completely gone, without touching anything. My favorite is how it SETS VCORE by itself. I can set it to 1.3V in BIOS, and when I startup AOD after boot, it LOWERS it to 1.25.
    It sucks and needs a TON more work, especially coordination between the mainboard company BIOS developers and the AOD developers. It is PATHETIC. I can tell that AMD writes it, and just THROWS it over the wall the mainboard guys, who are all used to doing their own thing anyway.
    Nasty nasty nasty software
    Asus M3A79-T W/ PII 720@3.6Ghz DTek Fuzion Water Block
    Raptor X 150G Boot Device & 3 X WD 500GB in RAID 5 Load Device
    8G OCZ Reaper @1066
    2xVisiontek 4870 Xfire @790/1080Mhz w/XPSC Water Blocks
    Razer Barracuda Sound System
    Windows Vista 64 Bit SP1
    LG 24" 1920X1200
    Xtreme Cruncher
    Apr 2008
    Ohio
    I am having no issues with AOD on my new board (in sig) nor on the K9A2 Plat. On the Plat i could get better over clocks using AOD, then using the bios.
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
    Banned
    Jun 2008
    personaly i dont see anything funny about it, i love my AX78, and rate it up there with a few cracking boards i have had, including the ECS K7S5A.
    this board has not let me down once, even though AOD has wrecked it a few times.
    personaly i have been trying this kind of app for years, whether it be speedfan/crystal cpu and so on.
    only time i found any to work, was on my forementioned ECS board, the northbridge would not go above 140 mhz, but with speedfan in windows i could hit 166 mhz.
    last time i used AOD (new version) i dropped the ht multi to 8 phenom multi to 10 and upped the FSB, and resulted in lock up.
    now i know how to flash a bios, and i think you will all agree, its a nailbiting process, evertime i do it, i panic a little.
    now what if a newbie guy comes along, "hey AOD, im a O'clocker now" changes a few settings and corupts the bios?
    for a newbie thats an RMA, for us its a bios flash
    i love the concept, really i do, but i dont think its stable enough for widespread newbie use yet
