Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Copper and Aluminum Galvanic Corrosion
Hybrid View
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Its been a month since i ran h20 on my blackops here with a koolance watercoolink kit. Thanks a lot to Koolance again!
    And many thanks to DIMAS for his benchtable in ferrari red!
    CPU Block is gold plated copper, nb block is our 4in1 block with the alu top, so copper and alu mixed, and the Koolance radiator is pure alu. Ive run 1.7v chipset voltage and thanks to the tropical climate the ambient temp is high, around 25 degrees, and its quite humid here, even in the office. I didnt even use destilled demineralized water, i just used plain tab water which contains tiny amounts of minerals, salts and acid, and i mixed in some of the koolance liquid that prevents corrosion and supposedly improved the temperatures slightly as well.
    Aaaaaannnnnnd:
    *drum roll*
    as you can see... no corrosion whatsoever ... the color of the water didnt change, its still clear blue greenish from the koolance additive, and the surfaces still look new. Well, not entirely new and shiny, but they didnt look shiny when i got the board already
    Im not sure but i think this board has been under dry ice or ln2 already before i got it, or at least the block on it
    The hoses turned slightly milky but thats always the same with the silicon hoses since they suck up some of the water that flows through them.
    I will check the waterblock and the water every month or two and will post updates here. For now im 100% sure there wont be any issues whatsoever, even after years, as long as you use an aditive like the koolance one that prevents corrosion. Those additives are very cheap add a nice look to the water, plus they prevent bacteria and algea growth as well, so the question should really be: why NOT use an additive?
    Xtreme X.I.P.
    Nov 2002
    Shipai
    I finally found the link i was looking for before when people discussed galvanic corrosion when mixing copper and alu in a loop:
    http://www.overclock.net/water-cooli...waterloop.html
    left is copper and alu mixed, right is from pure copper loop.
    Both blocks have been used for YEARS as stated by the thread starter.
    I assume they were used for 2 years, and probabaly with some additive to prevent corrosion. So like i said earlier, there will be corrosion, but it will be negectible... unless you plan to use your waterblocks for 5 years or more and care that they keep that shiny "like new" look.
    Jul 2008
    My father in Law was an lead engineer for Alcoa, and he built aluminum plants around the world. Before I started water cooling with the BlackOps stock north bridge block, I asked him about galvanic corrosion in the system, and mixing metals. He told me it was not something to worry about. The only time that they ever had problems with it was when they welded aluminum and copper tubing together, even then it would take years for the problem to develope. He said it was highly unlikely I'd ever see problems.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Quote Originally Posted by BMAF View Post
    cool, thanks a lot for that info!
    first i wasnt too sure, but the more i asked people who actually worked with copper and alu with watercooling equippment the more i realized that all this galvanic corrosion hysteria in the pc watercooling screne was quite overblown.
    from what i was told galvanic corrosion between copper and alu and most other metals is only a serious problem when they are exposed to salt water or other highly electrical conducting liquids.
    this doesnt mean mixing copper and alu is a good thing tho!
    we will try to go for an all copper solution for sure!
    I just want to show that there is nothing to worry about, there are some people who thing mixing copper and alu in a watercooling loop will mean the blocks will rust away and within a few months they will have holes in their blocks and radiators with water leaking out. thats def not the case
    Feb 2008
    Quote Originally Posted by saaya View Post
    Most people arent worried about thsat, their worried about the white gunk that it can create in the water that will build up inside the blocks and radiator or anywhere there is restriction.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Quote Originally Posted by Zaskar View Post
    havent seen any so far... so what does this white gunk do that i should be worried about?
    will it sneak out of my h20 loop one day and start to nibble on my leg?
    Oct 2007
    US, Michigan
    That is not true, while the one on the left looks like it has just a little corrosion, the problem isn't only there. Galvanic Corrosion causes a layer on the top of the block, reducing how well it works. Imagine a EK Supreme, that uses it's micro-channels to help cool the metal. If there's a thin layer of less conductive crap on it (not to mention the fact that the additive lowers the conductivity of the water), then it's not cooling nearly as well as it should.
    It's like running an engine on oil that is 15,000 miles used. Yes it will work, yes it will lubricate, but it's not doing nearly as good as it should. It can lead to blockages and the raised viscosity of the crud infested oil makes the engine work harder to do the same amount of work.
    Personally, if I'm spending that much money on cooling, I don't want to include things in my system that will lower it's cooling potential over time.
    D-Tek Fuzion quad nozzle & MCW30
    8800GTS 512 @820/999/1998 with a MCW60
    2xMCP655b
    1xMCR320 and 1xMCR120 with 4x Yate Loon SH's
    2x Raptor X
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Quote Originally Posted by WoZZeR999 View Post
    i know, thats why were working on a better solution.
    this is our first attempt at a h20 solution and the goal wasnt to make the best h20 solution to begin with, but a combo block that can be used for air, h20, dry ice and ln2 cooling at the same time. and even with all those compromises i think our cooling solution is almost as good as the asus one for air cooling, better than the asus one for watercooling, and it can do dry ice and ln2 which you cant do with the asus one, so...
    plus i think the cooling perf degradation in having a thin layer of oxidized metals on top of the blocks surface isnt dramatic. lets say you get even 4 degree celsius worse temperatures... compare that to aircooled and your still 10 degrees cooler at least, and all that with a silent h20 system compared to having several fans in the system.
    so yeah, its not the perfect solution at all, we never claimed that, sorry if it sounded like that. despite the galvanic corrosion and not perfect waterblock design i think its a really nice cooling solution and quite innovative, even if it looks pretty ugly (sorry sham ) and doesnt performs slightly worse than other solutions when you just wanna aircool.
    Quote Originally Posted by RAYTTK View Post
    Hello , anyone wishing to change there top can purchase one made of delrin from chilledpc, £7.99
    sweet! thanks for the headsup!
    any pics of the final ones?
    mirror finished?
    Jul 2007
    ARIZONA
    exellent info !!
    [SIGPIC][/SIGPIC]
    PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
    FOXCONN MARS
    COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
    BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
    OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
    Quattro 1000W
    Radeon 2-4850's in crossfire
    OCZ Vertex SSD thanks Tony!
    ALL PIPED INTO HOUSE AIRCOND ;}
    *QUANTUM FORCE* saaya & sham rocks !
    *REAL TEMP*
    At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
    *MEMSET* Felix rocks !
    *SUPER TEC MAN* UncleJimbo rocks !
    OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
    Aug 2006
    Oklahoma
    Thats what i have always said.
    Yes it isnt a good idea to mix metals.
    As it will take a LONG time for anything to happen.
    I have mixed titainium,alu, and (reynolds 853 steel) along with
    chromely steel for years with no problems.
    Really the only time you would worry is if the thermal cycles/temps are
    extremely high and low.
    But some people want to fight if some one else mentions it.
    _______________
    Q66@3.8ghz
    Rampage/Maximus SE hybrid W/C. 4 gigs OCZ reapers.
    4890,s CF Dual loop rocketfish case.
    ^^^^^All shaken, (from the earthquake) not stirred^^^^^
    Quote Originally Posted by Vapor View Post
    There's a lot less voodoo in watercooling than is assumed
    The only thing future proof in electronics, is the electricity itself.
    Any one who relies on only one source of information is a fool.
    Jan 2008
    Grinchville Embassy; Santa Cruz, Aruba
    myth busted, thx saaya
    Q9450 @3.60 Ghz, Striker II Formula, Evga 9800GTX (863/2050/1200), 2X2gb 1100 5,5,5,18 D9's at 2.20V
    Cooled by: MCR320, D-Tek Fuzion V2, MCP335 w/ EK G3/8 TOPS, Full BP high flow 1/2" fittings
    Oh and Vista Ultimate (i know, I KNOW!)
    May 2006
    To the OP - thanks for posting your results. Who woulda thunk that corrosion inhibitors actually inhibit corrosion? How novel!
    Rude comments removed - STEvil.
    Play-toy Rig: QX9650/Maximus Formula/Mushkin Redlines 2x1GB/3870X2 + 3870/Raptor-X/Zalman HP-1000/XP Pro-32 and Vista 64/3x12 Rad + EK-Supreme + Swiftech MCP-655 on the CPU/3x12 Rad + EK block + Koolance RP-1000 on the 3870X2/2x12 Rad + Koolance full block + Koolance RP-1000 on the 3870/1x12 rad + EK blocks + Koolance RP-1000 on the NB/SB/VRMs/Modded Lian Li Cube/SilenX fans.
    Image processing rig: Q6700/Blitz Formula SE/Mushkin DDR2-8500/HIS 3870/Raptor-X/Mushkin 800 watt PS/ Thermalright IFX-14/Armor w/ 25cm door fan.
    Jul 2008
    UK
    Asus P9X79PRO, EK MOSFET H20,
    3930K @ 4.8 Full Nickel HF Supreme
    EVGA classified GTX 780 Hydro copper 4 x 4gb Mushkin 1600 @1.5v
    2 X 250 GB Samsung evo RO, 3 x 640 WD Blacks Storage, Corsair AX1200, Phobya Nova 1080, Fesser 120,with GT 1850's
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    think about that small layer in a copper RAD, it would add alot of restriction, and i think t hat u guys have a better solution than asus for liquid and air, and at least urs isnt full aluminum like asus dose now
    also do the heatpipes that that HS has work with LN2 or dice to cool the pwm
    edit, and next time use g3/8 its awesome now that bitspower makes a metal g3/8 i would like more stuff with it that just my pump its got alot more aria with that extra 1/8" diameter
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Quote Originally Posted by zanzabar View Post
    3/8 inch, got it...
    full copper, roger
    block design as unrestrictive as possible right?
    about the rad, well there you actually have such a huge surface that i doubt it makes a difference at all. if anything it might restrict the flow in high perf blocks with thin fins and nozzles and increase the thermal resistance cause of a thin layer of corroded atoms... which might happen after a couple of months to years... but with the propper water additive i dont think even that is a problem
    Xtreme X.I.P.
    Nov 2002
    Shipai
    here are 2 pics of the deldrin top from ray in case anybody is curious on how they look
    Oct 2007
    ^^ Where do you get those? Because Corrosion isnt a Myth. It happens, you need something like Swiftech Hydrx to keep it out.
  18. #18
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Quote Originally Posted by btdvox View Post
    of course its not a myth, but corrosion causing leaks or destroying blocks is a myth, at least from what i know and many people and manufacturers told me.
    Quote Originally Posted by fart_plume View Post
    one of the biggest things that will cause corrosion is the ph of your coolant if it is any where above or below neutral you will have galvanic reactions. the minerals, biologicals, and dissimilar metals are secondary to this. Just get a fish tank or pool ph tester and see where your coolant is on the ph tables.
    thanks for the heads up!
    Quote Originally Posted by BulldogPO View Post
    Worst case of galvanic corrosion I have ever seen was in my work, on machine that grinds rotogravure printing cylinders.
    Machine´s outer panels are made of stainless steel and those cynders are mostly copper, that grinded copper goes sometimes to contact with stainless steel and there are also water in system for coolant and lubrication. So if you leave that copper dirt lying over those stainless steel panels thay will corrode into it and then you cand remove it anymore, a week seems to be maximum time between cleaning machines stainless steel panels.
    you mean the copper leaves greenish/blueish marks?
    have you tried ketchup yet?
    ketchup is awesome to remove corroded copper marks and make it look all orange and red again
  19. #19
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Its been 2 months, we are moving offices so i had to disassemble the loop anyways.
    i just opened the block and took a pic for you guys:
    i dont really see any changes compared to 2 months ago...
    theres a slight greenish color on the edge of the base and i noticed some white-ish green-ish stuff on the top of the waterblock:
    it looks like corroded aluminum and copper, so far, nothing to worry about though.
    considering that this loop has been running for 3 months im surprised how few corrosion signs ive seen so far.
    either corrosion really isnt that big a deal or the koolance anti corrosion additive is doing a really good job
    This is the koolance stuff im using:
    http://www.xoxide.com/koolance-liq-700bu-b.html
    its also available in yellow/green red and purple i think, and its uv reactive too, not 100% sure about the latter, but according to google there are koolance uv reactive mixes. even if its not, to get uv reaction you only have to add a few drops of the right stuff, so... its easy to prepare your perfect h20 soup
  20. #20
    Xtreme X.I.P.
    Nov 2002
    Shipai
    ______ JULY _____ ___ SEPTEMBER ___
    Heres a compare, different light, angle and distance.
    actually the new pic looks even better than the older one
    the pics suck, i know :P
    but i think its enough to conclude that there isnt any serious corrosion going on eating through the blocks that will cause a leak anytime soon
    the copper block still looks like copper and isnt all green or black, the alu top is still black and doesnt look corroded except for some small white-ish marks on the side
  21. #21
    Jun 2007
    Long Beach, CA
    I would like to show you guys what the North block will look like using the metal block (black) vs a copper one. I ran 1 loop for about 3 months using the following parts. Distilled water, Swiftech Hydrx coolant, Pentosin antifreeze (G001100) I am hopping Foxconn did not skimp with the new X58 board BloodRage North Block? The sad thing is I was given a NEW all Copper block for a replacement, but I was to lazy on switching them.
    CPU: Intel Core i7-4770K 4.8GHz
    MOBO: GIGABYTE GA-G1.Sniper M5 MATX 1150
    MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31 1T
    GPU: 2 x eVGA GTX 780 SC
    SOUND KRK Rokit 5 Limited Edition White Studio Monitors
    SSD: 4 x Samsung 128GB Pro's Raid 0
    PSU: SeaSonic Platinum 1000W
    COOLING: 2 x Alphacool NexXxoS UT60 Full Copper 420mm 6 x Swiftech Helix 140mm Fans
    CASE: Lian Li PC-C32B TECH STATION MOD build log coming soon
    MONITOR: ASUS VG278HE Black 27" 149Hz
    O.S: Windows 7 Pro x64
  22. #22
    Wanna Pull My Finger?
    Sep 2007
    Oklahoma
    Donate to Xtreme Systems!
    Now Showing:
    Gigabyte x48-DQ6, Q6600,OCZ 1066 Reapers,2 750gb seagate 7200.11 hd, BFG 8800GTS 512,PC P&C 750 Quad psu, 24" Sceptre lcd, Antec 900
    my wife's system now!
    Intel C2D 6400, Zotac Matx mobo, 1gb kingston mem, Nvidia 7050, I Feel really Good now!
    Jon C2D 6600 Zotac mobo 1gb mem............................................... ................. HTPC qx6700@3.0ghz
    Annabelle Amd 3800+@2.4ghz, Biostar mobo, 1gb ocz pc4500 beta's................. Optyx2 opty165@ 2.1 ghz
    'Want a real high?
    Come crunch WCG and you'll feel like your on QuadCaine"
    First loops are like first sex, all hands and thumbs till you figure out what goes where, then it's what ever works best for you.
  23. #23
    Jul 2008
    UK
    As stated in earlier post top is available from chilledpc in the uk, priced £7.99. check mine out now its fitted - http://img206.imageshack.us/my.php?i...ict6171az3.jpg
  24. #24
    Oct 2007
    No where in North america?
  25. #25
    Jul 2008
    UK
    Chilled PC will post to US.
