Page 139 of 245 FirstFirst ... 3989129136137138139140141142149189239 ... LastLast
Results 3,451 to 3,475 of 6110
Thread: "ASUS P5Q Deluxe discussion".
  1. #3451
    Xtreme Mentor
    Aug 2008
    Australia
    Quote Originally Posted by Forsakened View Post
    Guys, if someone is far way from their multimeter, what are they to trust? :p
    My multimeter is at home, and im at UNI.. not going home for another month or so.. i set 1.28V (cpu vcore) in bios and DISABLED LLC.. and CPU-Z shows it as
    1.23-24 fluctuating between the values =/ i thot the board overvolted and not under?
    using the latest 1306 bios btw
    Also, is it normal for coretemp to show the two cores as having different temps? (48C and 42C) in my case (tjmax = 105C)
    Edit: Seems like my board doesnt like x7 ratio =/ =/ currently @ 425x8 @ 1.28vCore (bios) 1.24vCore (CPUZ)
    Other voltages (vPLL, vNB, vFSB,) overvolt by a small amount when set to the second lowest value available for each (auto and the lowest available value overvolt a lot, especially when overclocking), vDIMM overvolts about 0.07 - 0.09v. Vcore however undervolts from bios set value. What cpu-z is showing you can be taken as correct.
    If you have a 45nm wolfdale, yes it is common that the temp sensors show different temps, as the wolfdales have dodgey sensors. They only really work and become accurate-ish when very close to the tjmax (100*C) and are nowhere near accurate at normal operating temps.
    Ci7 990X::Rampage III Extreme::12GB Corsair Dominator 1866C7GT::2 x EVGA SC Titans in SLI::Corsair AX1200::TJ07::Watercooled
    Ci7 920 3849B018::Rampage II Extreme::6GB GSKILL Trident 2000C9 BBSE::EVGA GTX580::Antec Signature SG850::TJ09::Aircooled w/TRUE 120X
  2. #3452
    Sep 2006
    i want to try 533 or 555 fsb but which settings to i use need help i try some setting but system don't boot
    Asus P5Q Deluxe @bios 1702 / E8500 E0 @4.23 with TT Big Typhoon / 2x2 GB Corsair Dominator PC8500 / Zotac GTX 260 / 2x320GB Seagate 613AS @Raid 0 + 750GB Samsung F1 @Storage / Asus 2014S1T / TT Armor + MX with Nanoxia Dual 120mm / Silverstone Decathlon 650w
  3. #3453
    I am Xtreme
    Sep 2006
    Quote Originally Posted by s1Lv3r View Post
    You got PM
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
  4. #3454
    Xtreme Cruncher
    Jun 2008
    pacific NW usa
    i have a quick question,is it better to drop my multi-down and go for higher fsb on my e8500,or is that just for getting a better overclock on my ram.
    _________________________________________________
    ............................ImAcOmPuTeRsPoNgE............................
    [SIGPIC][/SIGPIC]
    MY HEATWARE 76-0-0
  5. #3455
    Xtreme Mentor
    Aug 2008
    Australia
    @ s1Lv3r - What have you tried?
    1.52vPLL/1.12vFSB/1.26vNB/1.32v Vcore/2.14v vdimm
    1:1 FSB : DRAM ratio
    That allows me to hit 590 FSB & bench at 580 FSB no problems.
  6. #3456
    Sep 2004
    Karachi, Pakistan
    Thanks for the input guys!
    If on this P5Q-D the bios undervolts.. then is it safe to set 1.3-1.35vCore in the bios with these 45nm Wolfdale chips?
    My System
    Asus P5Q Deluxe 1306 | E8200 |Noctua U12P w/ NFP12 | G.Skill PC8000 4GB | Asus ATi 4850 512MB | Corsair 650W | Coolermaster CM 690 | WD 320GB | WD RE2 500x2 | HP w2207h 22" LCD
    HTPC-Fileserver
    Asus M3A78-EM 1206 | Phenom X3 8450 | G.Skill PQ PC2-8000 4GB | Sapphire ATi 3470 | Vantec 520W | Lian-Li PC75B | WD 250GBx2 | Seagate Barracuda 7200.10 750x2 |
  7. #3457
    Xtreme Mentor
    Aug 2008
    Australia
    I run 1.38125v bios and I get 1.36v idle/1.32v load with LLC disabled.
  8. #3458
    Sep 2004
    Karachi, Pakistan
    Thanks! Will give it a shot..
    Guys Prime95 Blend just failed on Core2 after about 5 hours
    My OC parameters:
    Code:
    E8200 C0/G.Skill PQ PC2-8000 4GB/P5Q-D 1306
    AI Overclock tuner: MANUAL
    CPU Ratio Setting: 8
    FSB Frequency: 425
    FSB Strap to North Bridge: 333
    PCI-E Frequency: 100
    DRAM Frequency: 1021
    DRAM Timing Control: Auto (5-5-5-15)
    DRAM Static Read Control: DISABLED
    DRAM Read Training: DISABLED
    MEM. OC Charger: ENABLED
    AI Clock Twister: AUTO
    AI Transaction Booster: MANUAL PL10 ALL PULL-INS DISABLED
    CPU Voltage: 1.28125 (1.24v CPUz)
    CPU GTL Voltage Reference: AUTO
    CPU PLL Voltage: 1.52
    FSB Termination Voltage: 1.14
    DRAM Voltage: 2.00
    NB Voltage: 1.16
    NB GTL Reference: AUTO
    SB Voltage: 1.10
    PCIE SATA Voltage: 1.50
    Load Line Calibration: DISABLED
    CPU Spread Spectrum: DISABLED
    PCIE Spread Spectrum: DISABLED
    CPU Clock Skew : AUTO
    NB Clock Skew : AUTO
    CPU Margin Enhancement: OPTIMIZED
    C1E Suppport: ENABLED
    Max CPUID Value Limit: DISABLED
    Intel Virtualization Tech: DISABLED
    CPU TM Function: DISABLED
    Execute Disable Bit: DISABLED
    Screenie:
    With this new bios and settings i havent yet ran Memtest, only Prime95.
    What do you guys reckon i should tweak?
    Thanks!
    My System
    HTPC-Fileserver
  9. #3459
    I am Xtreme
    Sep 2006
    Thanks!
    Try these mate : leave the ram tweaks alone at first, see if this gets stable... ( was the cpu small FFT stable with that voltage )
    FSB Frequency: 425
    FSB Strap to North Bridge: AUTO
    DRAM Timing Control: Auto (5-5-5-15) --> set TRFC to 55 too
    DRAM Read Training: AUTO
    MEM. OC Charger: AUTO
    AI Transaction Booster: AUTO
    CPU PLL Voltage: 1.54
    FSB Termination Voltage: 1.24
    DRAM Voltage: 2.00
    NB Voltage: 1.24
    SB Voltage: AUTO
    PCIE SATA Voltage: AUTO
  10. #3460
    Xtreme Mentor
    Aug 2008
    Australia
    1.24v vFSB is too high IMHO, it above intel's rated maximum of 1.15v. I don't need to increase it at all 1.12v is fine. The vPLL should also be OK at 1.52v I have not needed to increase mine at all but I do realize each cpu is different. I feel he should increase vcore a notch or two to attempt to stabilize it, as at least the vcore has more safe adjustment left in it. I agree with the rest of it though.
  11. #3461
    Jun 2007
    Finland
    Quote Originally Posted by CryptiK View Post
    Snip. Vcore however undervolts from bios set value. What cpu-z is showing you can be taken as correct. Snip
    Is this correct? Does it apply for instance to bios 1306?
    I'd really like this to be to true as it would allow me to gain some clocks because I wouldn't want to go over 1.375 vcore real LLC enabled.
    ASUS P5Q DELUXE
    Intel Q9450
    Mushkin 4GB
    Asus GTX260
  12. #3462
    Sep 2004
    Karachi, Pakistan
    Quote Originally Posted by Leeghoofd View Post
    FSB Frequency: 425
    DRAM Voltage: 2.00
    NB Voltage: 1.24
    SB Voltage: AUTO
    Trying out those settings now, Thanks! and no i didnt try Small FFTs only Blend
    BTW, i left the vCore as it was.. 1.8125
    Now IDLE cpuZ is showing 1.264V and LOAD vCore is 1.232V =/ =/
    Started small FFTs now to see if it works.. but why the opposite affect with vCore? shall i enable LLC?
    My System
    HTPC-Fileserver
  13. #3463
    Sep 2006
    You got PM
    i try your setting and run wprime 1024mb with 8.5 multi and 1.325 vcore temperature near 69 72 C i must change my big typhoon now i try this setting with 1.3 v core
  14. #3464
    Aug 2005
    Austin, Texas
    im still having those cold boot issues. NB Voltage or Vcore bumps didnt help at all. Its completely stable otherwise so I dont know that the deal is. I guess I'll give the modded 1306 bios a try tonight.
    7820X | Asrock X299 Taichi XE | Gigabyte 1080 Ti Xtreme | 32GB Memoriez | Corsair HXi1000 | 500GB 960 Evo
  15. #3465
    Feb 2006
    After getting a stable OC, I went back to check on lowering voltages etc. Ends up I was .005 off on my 0/2 gtl setting, tho I needed to bump my vcore 1 notch, which gives me 1.272v Load I also got my VTT down to 1.26v Stable from 1.30v. Nice tradeoff I would say.
    Funny thing is looking back at my notes, I had tried 0.670 for that gtl in the past, but my other settings must have been way off at the time.
    Larry
    Q9650
    Asus P5Q-D Bios 1406
    280 GTX FC Block
    2x2gb OCZ Flex II PC2 9200
    Water Cooled/ Iwaki MD20/ D-Tek Fuzion
    XFX 850 Watt
    OWC SSD
  16. #3466
    Jul 2008
    Quote Originally Posted by Budwise View Post
    try these settings...
    CPU Spread Spectrum: AUTO
    PCIE Spread Spectrum: AUTO
    disabling spread spectrum can cause a no boot.
    clock twister settings are notoriously unstable.
    HTH
  17. #3467
    Sep 2004
    Karachi, Pakistan
    FSB Frequency: 425
    DRAM Voltage: 2.00
    NB Voltage: 1.24
    SB Voltage: AUTO
    OK so priming small FFTs was fine for about 8 hours and then i stopped and it changed the FSB to 450 and upped the vCore from 1.28125 to 1.3
    Then two things happened:
    1) Enabling LLC allowed to run Prime95 for exactly 1 minute before Core 2 failed.
    2) Disabling LLC hanged XP when starting Prime95 torture test and rebooted the system =/
    What you reckon i should tweak now?
    thanks
    Edit: Oh and CPUZ 1.47 shows it as 450x6 =/ but validation shows up as 450x8.. wtf?
    Edit #2: When Prime95 starts, the ratio in CPUZ goes from 6 to 8.. and a few seconds later core 2 fails small ffts =/
    Edit #3: Disabling C1E support, stopped that ratio fluctuation and i booted into windows @ 460x8.. but again core 2 in prime 95 failed both small FFT and blend within 45 seconds =/
    My System
    HTPC-Fileserver
  18. #3468
    Dec 2007
    Ontario, Canada
    Well at 3.4ghz i wanted to see what i can do with my ram ....
    I tried 1152mhz, but it rebooted at windows scroll bar = more volts or timings adjusted, but i never went for it ... instead i wanted to see what i can do at 1.96v = Mobo Overvolts to 1.98-2.00v, but i set to 2.0v = Overvolts to 2.04 and i error out ... thats weird man..
    Here is where it leveled off at 1133mhz ant the volts i am running at 24/7.
    **PC Specs**
    - Intel E8600 E0 @ 4.2ghz @ 1.33v full load (Vid 1.25) Batch # Q822A441
    - Asus P5Q Deluxe P45 (Bios 1402)
    - T-Right Ultra 120 Extreme (lapped), 1 x Noctua P12
    - 1 x ATI HIS 4850 @ 700/1100
    - 4gb G.Skill F2-8000CL5D-2GBPK @ 1008mhz
    - TT ToughPower 650w
    - 1 x 640GB Seagate Sata II
    - Antec 900 Case
    - Vista 64bit SP1 and All Useful Updates
    **My Template for 4.2ghz speed**
    [URL=WILL MAKE ONE UP SOON[/URL]
    Orthos Prime (Blend) Stable 16hrs
  19. #3469
    Sep 2004
    Karachi, Pakistan
    OK figured out the prime crashing problem!
    Turned OFF LLC and kept FSB @ 460 and dropped the ratio down to 7.5.. its been Prime stable for 8 hours (small FFTs) going to let it blend while i attend classes =D and then will bump the FSB once i get back .. oh and this is with a few voltages lowered!
    Me thinks Iz liking 1306 =D
    Edit: Prime95 Blend failed after 8 minutes, i left a loop of 3Dmark and the GPU hung, and VPU recovery recovered the device. Could it be the OC (CPU, GPU/MEM are at stock), or the fact that the PWMs (correct term?) on the 4850 arent covered since im using an Accelero S1 Rev2 with ramsinks on the rams only =/
    My System
    HTPC-Fileserver
  20. #3470
    Feb 2006
    Quote Originally Posted by BeastNotro View Post
    Hmmm.. so your saying your ram errors out over 2.04v?
    Mine are running 480fsb 1:1 at 2.1v.(2.0v set in bios, 2.1v measured on board)
    Larry
    Q9650
    280 GTX FC Block
    XFX 850 Watt
    OWC SSD
  21. #3471
    Dec 2007
    Ontario, Canada
    Quote Originally Posted by Big Lar View Post
    Larry
    Well that was when i was trying 3.6ghz and set in Bios to 2.0v = Overvolted on other bios 1103 and 1201 to 2.04-2.06 and i would error out in linpack 4-5 right, dropped it to 1.96v = (1.98-2.00v Overvolted) in bios and all was fine... weird eh? . and ram was only around 900mhz then.
    Could have been a bios issue, but i have not since tried that again and now that i am on Kets Modded 1306 bios which has the added premium memory tables, maybe it will work .... but i am not going to try it now as i am awaiting for my E8600 to arrive (it better be today .. )
    So i will play around then or in a day or so after getting it as who knows it maybe a bad E8600 in temp wise and so forth.
    **PC Specs**
    - Antec 900 Case
  22. #3472
    Aug 2005
    Hey, guys can someone review my settings again. For some reason I was getting random video driver crash only in vista 64 before I updated bios. Any reason why you guys stopped recommending pcie freq. @ 101, I see posts with pcie@ 100 now?
    -24hrs prime stable, 100 passes of linpack stable burn test, 12hrs hci memtest/memtest86+ stable.
    -Haven't had the video crash since I updated bios, but I'm not sure if it's still there. The crash would happen with pcie @ 100 or 101 with c1e off or on and with performance level manual or auto..
    Code:
    e8400/2x2gb gskill ddr2-800
    CPU Ratio Setting: AUTO
    FSB Frequency: 400
    PCI-E Frequency: 101
    DRAM Frequency: 801
    DRAM Static Read Control: AUTO
    AI Transaction Booster: MANUAL PL11 ALL PULL-INS ENABLED
    CPU Voltage: 1.25625 (1.24v CPUz)
    FSB Termination Voltage: 1.26
    DRAM Voltage: 1.90
    NB Voltage: 1.26
    SB Voltage: AUTO
    Load Line Calibration: ENABLED
    CPU TM Function: ENABLED
    Execute Disable Bit: ENABLED
    Intel Speedsteb: DISABLED
    Intel C-state: ENABLED
  23. #3473
    Xtreme Mentor
    Aug 2008
    Australia
    Perhaps your kit just didn't like high voltage? I had an old corsair 6400 kit with quimonda IC's and they refused to boot when at 2.1v or higher.
    Bi Lar's kit may just be a little more tolerant to voltage than yours. Strange though, it would be worth re-testing.
    Quote Originally Posted by plion View Post
    Code:
    FSB Frequency: 400
    DRAM Frequency: 801
    DRAM Voltage: 1.90
    NB Voltage: 1.26
    SB Voltage: AUTO
    Your settings look ok, nothing stands out as possibly causing 3D crashing.
    So this crashing only happens with Vista 64, not 32 or in XP? How long does it take to crash out of a game usually? Is it any particular game that does it? Is your video card overclocked? What drivers are you running? Are you overclocking your video card? What happens when you run the system/card stock?
    I would just wait and see if it happens again, if it seems stable since the bios update, just keep testing it and report back if it happens again.
    I run PCI-E at 100, always have. 101 was recommended by some guys as a preventative measure as I believe on older boards it stopped some problems people were having, but I don't believe it is necessary on these boards.
  24. #3474
    Sep 2004
    Karachi, Pakistan
    Update: 480x7.5 (3.6Ghz @ 1.31 LLC Enabled) booted fine into windows .. And Prime95 Blend failed in 8 minutes, small FFTs lasted 2hr 56 minutes (failed on core 2, core one was going strong)
    Settings below:
    Code:
    CPU Ratio Setting: 7.5
    FSB Frequency: 480
    DRAM Frequency: 961
    DRAM Timing Control: Auto (5-5-5-15-3-55-6-3)
    CPU Voltage: 1.32500 (1.31v CPUz)
    FSB Termination Voltage: 1.20
    DRAM Voltage: 1.92
    NB Voltage: 1.20
    SB Voltage: AUTO
    C1E Suppport: DISABLED
    Also, at my previous setting of 460x7.5, small FFTs were stable.. but blend failed after 8 minutes.. and i left 3dmark on loop, came back and saw VPU Recovery had recovered the GPU which had stop responding.. some D3D Devicelost error =/ (XP32, CAT 8.8)
    My System
    HTPC-Fileserver
  25. #3475
    Jul 2008
    try...
    FSB Termination Voltage: 1.14 or 1.16
    NB Voltage: 1.14 or 1.16 or 1.18
Tags for this Thread
