There are many games that do not support widescreen properly. These games usually let you set a widescreen resolution, but do not adjust the field of view (FOV) accordingly. This causes the top and bottom of the screen to be cropped. Because of this issue, I decided to develop a program that will adjust the field of view for the aspect ratio of your monitor.
NOTES
* You will notice a slight change when you zoom in or out with weapons.
* If you use Microsoft Windows Vista, you need to have either UAC disabled or run the program as administrator.
* If you're having problems with any of the Battlefield games, reapply the latest update and see if it helps.
SUPPORTED GAMES
These games are currently supported:
* Battlefield 2 v1.40 - v1.41
* Battlefield 2142 v1.10
* Battlefield 2142 v1.20
* Battlefield 2142 v1.25
* Battlefield 2142 v1.40
* Battlefield 2142 v1.50
* BioShock v1.0
* Call of Duty 2 v1.0 Single-Player
* Call of Duty 2 v1.3 Single-Player
* Call of Duty 4 v1.0 Single-Player
* Call of Duty 4 v1.2 - v1.7 Single-Player
* Call of Duty 4 v1.0 Multi-Player
* Call of Duty 4 v1.1 Multi-Player
* Call of Duty 4 v1.3 Multi-Player
* Call of Duty 4 v1.4 Multi-Player
* Call of Duty 4 v1.5 Multi-Player
* Call of Duty 4 v1.7 Multi-Player
* SEGA Rally Revo v4.060
ASPECT RATIOS
Here is a list of common resolutions and their aspect ratios.
* 640x480 = 4:3
* 720x480 = 15:10
* 720x576 = 5:4
* 800x600 = 4:3
* 848x480 = 16:9
* 960x600 = 16:10
* 1024x768 = 4:3
* 1152x864 = 4:3
* 1280x720 = 16:9
* 1280x768 = 15:9
* 1280x800 = 16:10
* 1280x960 = 4:3
* 1280x1024 = 5:4
* 1360x768 = 16:9
* 1440x900 = 16:10
* 1680x1050 = 16:10
* 1920x1080 = 16:9
* 1920x1200 = 16:10
USAGE
Just extract the zip, place the program file anywhere you want and run it. You may start the program at any time, whether the game is already running or not.
To use this program:
For Battlefield 2 and Battlefield 2142, edit the shortcut and add: +widescreen 1 +szx 1920 +szy 1200 (or whichever widescreen resolution you use).
For Call of Duty 4, you must set the in-game aspect ratio to standard (4:3) for this to work correctly!
1. Start Widescreen Fixer.
2. Select the game you will be playing.
3. Select the aspect ratio of your monitor.
4. Start the specific game.
5. Use the Numpad * (v1.00 to v1.06), Right Control (v1.10), or ; (Semi-Colon) (v1.10.1 to v1.45.1) key to enable or disable the fix.
link to website,
http://imk.cx/pc/widescreenfixer/
THANK YOU David Rudie
