On the asus maxmius SE.
1.65volts in the bios.
My Rig can do EpicFLOPs, Can yours?
Once this baby hits 88 TeraFLOPs, You're going to see some serious $@#%....
Build XT7 is currently active.
Current OS Systems: Windows 10 64bit
what sort of cooling did you use to get to 4.188mhz ??.. air ??
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
Nice job bro ! Next time close all your open programs like CPUz Everest and whatever the hell else you have open and your pi time will drop a bit
run it a few times and I think 11.6-7s will be easy![]()
Run something more CPU loading - 1M superPI is nothing, and show us your temps.
Here's what mine in summer with over 40* idle @ 1.51V can run 2x32M 4100mhz
and 32m 4g @ 1.44v
Also Mandelbrot test, 1.57v same temperatures 4232mhz:
In your tread for 17k 2006 I show you 3dmarks @ 4213mhz.
So 4180 1M nothing special with G0 and winter temps i presume![]()
Your system has nothing on mine, Plus Yours is water cooled and you can overclock your 8800 higher then I can. So shh... Your 4.2Ghz isn't nothing. Plus Try to deal with the maximus for a day, Its so hard to overclock right. Plus, I need another week till i find the max tweak for these board. It has better overclocking handle, but poor FSB Walls.
nice similar to my Q6600 L725A903 on Blitz Formula with Swiftech G4 storm water http://i4memory.com/showthread.php?t=4553 (But TR120E is excellent similar performance to my E6850 L720A489 did 4250+ Mhz on both Nautilus 500 and Thermalright Ultra 120 Extreme for 32M pi)
top temp during these run was 57C, so bite your tongue before you speak :P
1m SuperPI can't prove anything for you, so theres a 32m. I don't think thats the best time in the world for that clock, but I was also running Utorrent in the background and using no tweaks on my SuperPI tests.
After going into my performance kick mode :P
Here is my 32m PI again.
still stayed well under 57C
Nice quad! Same setup except for tuniq tower, L731B:
Wow guys, your results are all amazing !
I bought my Q6600 G0 because it was a bestseller, but i got a crappy batch with a high VID... i have a bad cpu cooler as well, and my knowledge in high OCing isn't that good, but when I get my watercooling system, i'll give my Q6600 a second chance
Tell me, in order to reach so high clocks, what are the other main options (mainly voltages i guess) you have to change in the bios ? I have a P5Q Pro, and i don't think it's gonna fsbwall me in anyways, am i wrong ?
Cheers,
Alex
Q6600 (VID : 1.325v) || P5Q PRO || 3GB Corsair || 8800 GTS 512 || 1.5 TB HDD || Thermaltake 550W || Antec 900 || Logitech G15 || Logitech G3 || Pioneer HDJ-1000 Headphones || Razer mousepad
WaterCooling System:
MCP 655 || XSPC 360 Rad || HeatKiller 3.0 Cu || 3 x NoiseBlock BlackSilentFan XL2 rev 3.0 || and some tubes/fittings etc
Very nice! Gotta love the Q6600.
Asus Rampage IV X79 Extreme 1305
Intel Core i7-3930K Processor @ 4.8GHZ 1.45V
G.Skill Ripjaw 1866MHZ 4X4GB 9-10-9-28
EVGA SC GTX 580 SLI 880/2200
Corsair H100
Coolermaster HAF932
Corsair 1000W HX Power Supply
Way to dig this out of the grave
[CENTER]The post counter is not an intelligence meter!Originally Posted by Massman
MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
Heat Team IRONMODS
