Darken, why do you think you need Vdroop mod ?
have you looked at software or bios ?
If so, DONT TRUST it m8.
Find a multimeter, Stick the black "pin" into ground/the 2 middel whires in a 12 Volt 4 pin molex, they are black.
Then put the read on the back side of the motherboard, at the coils. Look at the link above, it states that the coils are what you need to use.
Also, Vdrop and Vdroop are 2 different things.
Dont recall what is what.
But 1 ting is what the volt is at ilde = no load on CPU.
Then load, The volt will always droop from idle to Load, or somtimes even increase. But that is okay.
problem is how much the volt swings while under load = instability
And it is okay for you to give 1.4 Vcore in bios and only get 1.33 idle or load, stability is the important thing!
