Results 1 to 20 of 20
Thread: asus p5k-premium/E6750 @4ghz
    Sep 2006
    i got my chip to 4ghz today ,its on 1.56vcore
    http://www.xtremesystems.org/forums/...30#post2460030
    http://valid.x86-secret.com/show_oc.php?id=248440
    temps are 36c idle/max 59c
    intel G860
    asus p8z77-m pro skt1155 bios 1205
    Samsung 2x4b ddr3 1333@1600 8.10.9 1.53v
    MSI gtx560ti twin frozr 1gb
    1x120gb pny prevail elite/1x WD RE4 2TB
    Lg Slimline Dvd/rw sata
    Dell 2405FPW 24"
    Fractal Arc mii
    Xonar DX/Dell soundbar
    Hiper 580watt
    3.9ghz e6300-http://valid.x86-secret.com/show_oc?id=139796
    http://www.techpowerup.com/gallery/1834.html
    Jul 2007
    Finland
    Yet another 4 GHz on air. super.
    Aug 2007
    stockton, ca
    I like it. grats.
    --pak
    Q6600 400x9 1.5vcore
    P5kdeluxe Ballistix 2x1gb
    D5 coolrad32t Fuzion
    EVGA 8800GTS 320 600/900
    2xRaptor 36g Raid-0
    Creative X-Fi Extrememusic
    PCP&P silencer 750 copper
    Built for the sole purpse to play World Of Warcraft and troll XSforums.
    Heat
    May 2007
    Burlington Ontario
    what type of cooling and what are you using to monitor your cooling?
    hopefully coretemp .95.4
    Motherboard Asus P5K Deluxe
    CPU E6850 @ 3.8ghz 1.5Vcore
    Ram OCZ Reapers Pc8500 2gb 4:4:4:12
    Hard drives 1 x 74gb Raptor 10k + 1 x 250gb Cav for storage
    Case Lian Li 1200bPLUS2
    PSU Corsair 620w
    GPU EVGA 8800ULTRA (660/1080) 13223 on 3dmark06
    Watercooling MCP655, Micro res, Mcr320, Fuzion, EK full coverage GPU block
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    tighten your ram up 1000mhz 5-5-5- ?? nooooo
    4-4-4 @ 2.2v or 2.25 or 2.3v
    ballistix will do 1000mhz 4-4-4 easy.
    plug the cas4 will help your times.
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    Sep 2006
    it is core temp 95.4
    and i will try my timings on 4.4.4 at 1000.
    intel G860
    Dell 2405FPW 24"
    Fractal Arc mii
    Hiper 580watt
    Jan 2005
    Quote Originally Posted by Lestat View Post
    =( my ballistix don't do 4-4-4 @ 1000Mhz with 2.25V
    They'll do 5-5-5 @ 2.2V 1000 just fine, but for 4-4-4 I need to juice it quite a bit more
    That said, my system is already pretty darn fast even when I don't have it clocked to the max, right now I'm doing 1066 memory and only 2.66Ghz CPU just because I got tired of hearing the stupid heatsink, lol.
    Oct 2007
    OC.Team
    How About This E6750??
    good Job
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    great scores mate.. any pics of your rig ??
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    Nov 2005
    Germany
    1.56v is to much for 4GHz
    my new E6750 can do it with "only" 1.40v (on P5K-E)
    Xtreme Guru
    Apr 2005
    Finland
    Thought I'd post screens of some godlike E6750 from a swedish forum:
    http://aycu11.webshots.com/image/303...0266759_rs.jpg
    http://aycu31.webshots.com/image/282...3577914_rs.jpg
    The funniest part is that it only need 1.475v to be stable at 4GHz. Swedes are often lucky with steppings it seems, 3.8GHz seems like a pretty normal result for 24/7 usage for E6750.
    EDIT: Wow Chri$ch, seems like these G0 CPUs keeps getting better and better. Can you try and push it further than 4GHz to see how far it goes, like if 1.5v is used, would be appriciated. Hope Penryn will follow a similiar pattern.
    I remember when E6600 @ 3.6GHz 1.4v on air/water was godlike, these days it seems we're getting E6750/E6850 4GHz @ 1.4v.
    Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
    If all people would share opinions in an objective manner, the world would be a friendlier place
    Nov 2005
    Germany
    Quote Originally Posted by RPGWiZaRD View Post
    i tried 4.1Ghz but if the cores reach over 60°C the sys reboot
    for SuperPi it can do 4.32Ghz @ 1.60v.
    I think i must remove the IHS to get better temps....
    Edit: max FSB with Multi 6 & 7
    Xtreme Guru
    Apr 2005
    Finland
    Quote Originally Posted by Chri$ch View Post
    LOL, 60C would be fine if it's accurate, my E6750 @ 3.75GHz 1.52v goes up to ~68C in Orthos but is stable nonetheless.
    Wow 565 FSB at 7x. Mine does only about 7x505 stable at most but at 6x multi it does at least 515+ with stock mobo, cpu etc. volts even, any ideas why it's like that? I mean 7x505 is only 3.53GHz and it's stable at 3.75GHz at 8x multi and then I've tested up to 515 FSB at 6x multi and it was rock stable with every volt settings @ stock? Any reason for that? I don't get it why it doesn't go above 7x505.
    Nov 2005
    Germany
    yes, my old E6750 (4Ghz @ 1.424v) had no problems with 70°C to run stable, but
    only @ 4Ghz! But if i tried 4.1Ghz or more give it problems over 60°C (prime failure
    or reboot).
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    damn you guys.. when i bought my 1 e6750 right after when it was launched it sucked even with chilled watercooling ..all i was able to get out of it was 3.8ghz and a now i see peeps getting great OC results with much lower voltage than i was back then .. how depressing
    Xtreme Guru
    Apr 2005
    Finland
    Mine's very old too, about 2 weeks after official launch but seems for that time mine was fairly good. But today it's a bit depressing seeing these 4GHz results.
    If E6850 was maybe prioritized with good silicon at G0 launch, it seems now they have such a nice production rate for G0 stepping CPUs, they can really ship almost only good samples of any model and chip these days. That's my guess and perhaps we're now starting to surf on the edge of the wave when it comes to G0 stepping, I can imagine when Penryn arrives, these G0 results will slowly start decreasing again like E6600 today is a good example of when some does even barely 3~3.1GHz! So if you wanna break WRs with current gen then now's the time to pick your babies!
    Nov 2005
    Germany
    Mine is one of the first E6750 (L719)
  18. #18
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    damn you... now im even more depressed than i was before mine was L719A786
  19. #19
    Nov 2005
    Germany
    btw @ stock NB voltage & cooling
    Edit: mine is L719A874
  20. #20
    Oct 2007
    all i could get from my friends E6750 was 3.75 stable.. on air
