let's go discovering this new TR product
Thermalright....Si-128.
Here we start from the packaging:
As TR standard, is a carton box, full with everything you need:
Heatsink
wire clip to fix the fan
skt 775 mounting kit
skt 939 mounting kit
skt Am2 mounting kit (usually is not included !!)
thermal paste
sticker and instructions
Let's take a deeper look at details:
really big, and with large heat pipes
and a good lapped base
Great fins to optimal heat exchange
here's the detail of the "S" bracket to fix the HS on the standard 939 kit. You put it above the HS base , fix the 3 windowed bracket and turn the lever 90deg. to close it.
Detail of 775 kit: Really easy to fix: you put it on the HS base, push the pins into the mobo's holes and that's it..
To take off the HS, just turn the black parts and the pins will come up from the mobo. great !
And here's on an Asus P5wdh. Take a look at the cooling above mosfet zone.
Platform test:
ASUS P5wdh deluxe
Conroe E6700 Es step5 B1
2x1gb ddr2 Corsair 4.4.4.12
fan: Thermaltake 120mm
