I can't get 4GHz. I'm using a X3370 and 6GB DDR2 Kingston Hyper-X.
Is 4GHz just too much for this computer or am I doing something wrong?
I'm trying 450Mhz.
I'm trying 450Mhz.
RIP. My P5Q Deluxe is dead from ninth of August. :(
is anyone familiar with a board that goes by the name P5QD Turbo ? I can't find any information about it, maybe someone knows this model ?
Sorry to bump an old thread...
I have a P5Q Deluxe that I updated to 2301...finally. I set up all my settings, and it seems to work. However, I can't seem to find out what voltage vDIMM is actually running at. In the past, I ran 1.92V because that seemed to get me ~2.1V on BIOS 0704 (at least, I think that's where it ended up - 1.92V is definitely the setting I had). I carried over that setting, but I have no idea what it's actually running at. I've tried CPUID's HWMonitor, Speedfan, looking through the BIOS, and Asus' PC Probe II. Does 2301 not report vDIMM? Do I have a BIOS corruption somehow?
Okay...I tried reflashing. Didn't change anything :(. I also tried to load the old BIOS I had (0704) and it told me it's an old version and refused to load it. I guess I could use one of the DOS-based flash programs to force it to go back to 0704, but I'm kinda of wanting to have a newer BIOS installed. I know this is a really old board, but maybe someone remembers something about whether 2301 (or newer BIOSes in general?) don't monitor vDIMM?
To flash an old BIOS, you need the engineering edition of AFUDOS which can flash an older BIOS. I don't recall where I got mine (using 2.36 if I recall), but I needed it to flash older BIOSes on both my P5Q Deluxe and my P6TD Deluxe.
Just search for "afudos engineering edition".
I don't recall if my board allowed software measurment of vDIMM with PC Probe, as I've never used that software. Regardless, ASUS' boards rarely report the correct voltage anyway, and I'd recommend using a DMM if you want an accurate reading.
Has anyone successfully managed to get VT-X working with the P5Q Deluxe in Windows 7? I'm really stumped... I have a Q9550 CPU which supports the technology, and have tested the vt.iso at http://communities.vmware.com/docs/DOC-8978 which reports "VT is enabled on this core" for all cores. Yet in windows, using the Intel processor ID utility, I am missing VT.
http://i49.tinypic.com/jztc0w.png
Interestingly, if I disable Virtualization Tech in the BIOS, the Intel tool reports my CPU is VT compatible, with VT-X still disabled...
hey guys. managed to fix this by re-installing windows 7 sp1. no idea why that fixed it, but i'm not complaining.
i don't know if anyone is still rocking this mobo, but i experienced degradation on NB. Or something...
i was running
8.5X451
1.28 vcore
1.54 PPL
1.3 for nb
1.32 fsb
2.02 mem
1083 mhz, lighter,PL10 5-5-5-15-55
for 2 years. Then suddenly some games start to shutdown back to desktop. slowmo
Now after testing all settings for week. all is rock solid linX 30 pases, p95 blend 2800 mem 4h, memtest 1000% stable temps linx under 74c prime 58-64
All on PL8 and lower volts on cpu 1.256 (this was sweet spot on x38) WTF 775 is a great mystery
But i need to up NB to 1.38, FSB 1.36. ANY lower value i have errors. lower FSBv wont even post
i know this board overvolts but maybe my dont? i have newest board rev 03
I had this cpu on x38 maximus formula same cpuv 1.256 up to 474x8.5 (my vid is low1.1875 i don need much v)
hardware
q9550 E0, 4Gb 2x2 transcend aXeRam PC2-8500, noctua d14 inside coolermaster haf x+ a lot of fans
current stable settings
AI Overclock tuner: Manual
CPU Ratio Setting: 8.5
FSB Strap to North Bridge: 333
FSB Frequency: 451
PCI-E Frequency: 101
DRAM Frequency: 12-10 (1083 from memory cant remamber testing atm)
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15 (18tested)
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55 (60-65)
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: disabled
DRAM Read Training: disabled
MEM. OC Charger disabled
AI Clock Twister: light (tested lighter and modderate)
AI Transaction Booster: Manual
Common Performance Level [8]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.256V Bios
CPU GTL Voltage Reference (0/2): Auto
CPU GTL Voltage Reference (1/3): Auto
CPU PLL Voltage: 1.54
FSB Termination Voltage: 1.36
DRAM Voltage: 2.02
NB Voltage: 1.38
NB GTL Reference: Auto
SBridge Voltage: 1.2
PCIE SATA Voltage: 1.5
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Auto
NB Clock Skew : Auto
CPU Margin Enhancement: Optimized( same opt and pref)
i need to push this chip to 4ghz without burning components(cpu was stable 1.312 4.105ghz on asus x38MF ). this rig will go soon for my young bro. but i need to push it to limt now.
sorry for bad english
edit
no im not
