hi all!
as you can read from the title of this discussion, I have many problems with my new OS Windows 7 x64 Ultimate RTM .....
the first problem is when I had to install it from the dvd... around the beginning of the installation I received many times this errors, with blu screen
PAGE_FAULT_IN_NONPAGED_AREA
and also this with another bios and hard diskes combination:
STOP: 0X0000007E (0XFFFFFFFFC0000005, OXFFFFF8000C75ABB9, 0XFFFFF880009A82F8, 0XFFFFF880009A7B50)
well, I put all the bios in default and the installation started and ended without problem
...but I am sick, as all people in this forum, so I simply cannot have the system at default setting ...so I went inside the bios and I started to set up something more fast..
I did my older setting that I have used for 1 years without problem, completely stable on my XP SP3 :
  • put the ram at 445mhz
  • the strap I think is 333
  • the ram are on auto because I don't know how to setting good them..
  • cpu freq. is 4000 (ratio x9, I have e8400)
  • vcore 1,350v (i tried also to give much more (1,400v) for to be sure that it was not this, but nothing again blu screen
  • vram 2,08v.. in the bios I read around 2,13v so considering the ram that I have, from SPD, at 533mhz a couple of corsair wants 2.100v and other couple of crucial wants 2.000v
  • the timings, for what I see, I think that are set in automatic from spd, so I have 5-5-5-18
now, with the same settings, I can use without problem for days and days without rebooting or freezing my XP SP3... with the same settings I cannot enter in Windows 7 x64
I would like to understand what I can to try to do for to solve this problem...
I hope somebody have some ideas and suggestions...
thank you very very much !!
