Page 47 of 61 FirstFirst ... 374445464748495057 ... LastLast
Results 1,151 to 1,175 of 1523
Thread: msi 790 fx-gd70 thread
  1. #1151
    Jan 2007
    San Antonio, TX
    Quote Originally Posted by Panther57 View Post
    FlawleZ; I am using 1.7 with a 720BE. I am using the same OC settings as previous, but with 1.7 or because of thier own updates (.11 ATI) my 4870's memory has increased the memory to 1100 from 1080. My 720BE is a non-unlockable one. Very stable for me with 1.7 though.
    Quote Originally Posted by ggdh View Post
    Same here. 1.7 and 720BE runs 3.6GHz at 4 cores with no hassle. 3.9GHz at 3 cores done as well. I didn't checked any other BIOS versions except for 1.0 so can't compare.
    Quote Originally Posted by beta View Post
    core unlocking was unstable with all bioses before 1.5b4..
    Thanks for your input guys. I'll try out the latest BIOS when I get back from the holidays.
    Ryzen 3800X @ 4.4Ghz
    MSI X570 Unify
    32GB G.Skill 3600Mhz CL14
    Sapphire Nitro Vega 64
    OCZ Gold 850W ZX Series
    Thermaltake LV10
  2. #1152
    Feb 2007
    Guys,
    Quick question, should i improve alittle more my overclock, here are my specs
    AMD P2 955 3.8Ghz @ v1.41
    8gb OCZ Plat 1600Dual channel Ganged
    NB 2600 @ v1.3
  3. #1153
    Xtreme Enthusiast TheBlueChanell's Avatar
    Dec 2006
    Quote Originally Posted by rakesh27 View Post
    Guys,
    NB 2600 @ v1.3
    What OS are you running? 32/64 bit? I'm assuming you are running your ram @ 1333. What are your timings?
    Main: 900D - Prime 1000T - Asus Crosshair VI Extreme - R7 1700X @ 4.0ghz - RX Vega 64? - 32GB DDR4 3466 - 1TB 960 Pro -
    --- XSPC AX360 x3 - HK IV Pro - HK RX480 - HK 200 D5 - BP Compression ---
    HTPC: 250D - Prime 850T - Gigabyte G1 ITX - i7 6700K @ 4.5ghz - GTX 1080 Ti - 16GB 3200 - 1TB 960 Pro -
    --- ST30 x UT60 - Kyros HF - KryoGraphics 1080 - HK100 DDC - Monsoon Compression ---
    HV01: Define XL R2 - Prime 1200P - Asus Zenith Extreme - TR 1950X - RX580CF - 128GB DDR4 ECC - 512GB 960P - 4x 2TB RE
    HV02: Node 804 - Prime 850T - SuperMicro X1SSH - E3-1230 v6 - Vega FE - 64GB ECC - 512GB 960 Pro - 4x 6TB Gold -
  4. #1154
    Jul 2008
    this mobo can run quad cf of 5770?
    with drivers for win7 and vista, can i run quad CF of 5770?
  5. #1155
    Xtreme Cruncher
    Jan 2009
    Are you sure it's Ganged? I always thought that "Ganged" is for single cores only.
    SB 2600K
    MSI P67A-GD65
    8GB 1600/CL8
    GTX580
    64GB SSD
    4TB
    Xonar DX
    BeQuiet Straight Power 680W sleeved
    in
    Cosmos 1000, modded
    TC PA120.3+XSPC RX240mm+XSPC RASA+DDC1T+OCLabs top+EK Multioption 150+ EK-FC580
  6. #1156
    May 2009
    Ganges and unganged is memory...so why single cores......
  7. #1157
    Xtreme Cruncher
    Jan 2009
    I was not precise enough. When you are running applications that can utilize only one core then it is better to set your memory to "ganged" because you set there 128bit highway between CPU and RAM. In case of applications using multiple cores it is better to set it as "unganged" as cores will have access to memory through 2x64bit (as Phenoms has 2 memory controllers).
    At least I understood it that way and correct me if i'm wrong
    SB 2600K
    MSI P67A-GD65
    8GB 1600/CL8
    GTX580
    64GB SSD
    4TB
    Xonar DX
    in
    Cosmos 1000, modded
  8. #1158
    Xtreme Mentor
    Jul 2008
    Shimla , India
    For your viewing pleasure
    Seems i used the 5850s bit tooo much lol. Milkyway@home did this to my mobo lol rma'n now and yes cesariuth this run quad cf i run 5850*4 cf for milkyway@home
    Coming Soon
  9. #1159
    Jan 2007
    San Antonio, TX
    Quote Originally Posted by ajaidev View Post
    Wow, that's quite unfortunate ajaidev! I assume this was temperature related? What kind of temps were you seeing with your 4 5850's?
    MSI X570 Unify
    Thermaltake LV10
  10. #1160
    Feb 2007
    Guys,
    Im running ram in dual channel mode ganged at speeds of 1600Mhz the ram can handle 2000Mhz and OS im using is Vista64.
    Ive just started overclocking, already
    AMD Phen2 955 3.8Ghz @ v1.41
    8gb OCZ Plat 2000Mhz @ 1600 Dual channel Ganged
    NB 2600Mhz @ v1.3
    What do you think?
    I also have HIS Radeon 4870x2 + X-Fi Titanium Fatality soundcard, hopefully when Nvidea release 300 then i can make up my mind between NV300 or Ati5970.
    Is my overclock ok, ram timings are 1T 9-11-11-24, i havent bothered with ram everything is left at auto, only thing i did was CPU and northbridge.
  11. #1161
    NooB MOD
    Jan 2006
    South Africa
    It looks good, but those timings... Ouch! Can't you get them closes to 7-8-7 at the very least?
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
  12. #1162
    Xtreme Mentor
    Jul 2008
    Shimla , India
    Quote Originally Posted by FlawleZ View Post
    i dont think that it was temp related because the system was not in a cabinet but open air. I think the stress of useing all 5850's for a long period of time did that, so maybe something to do with over voltage or maybe the cap was faulty from first.
    Have sent the mobo for rma, the temps of the 5850 were under 80C at all time.
    Coming Soon
  13. #1163
    Jan 2007
    San Antonio, TX
    That's surprising. Roughly how long and how much use was your board setup with the 4 way CF? I don't recall anyone else experiencing this problem so hopefully its just an isolated occurrence. Hopefully the RMA process will go smoothly with MSI.
    MSI X570 Unify
    Thermaltake LV10
  14. #1164
    Dec 2006
    Anyone else get hyper transport sync flood error whenever you raise cpu-nb volts past default?
    It's been an issue for me since bios 1.71 but It could just be a coincidence. I'm not even sure cpu-nb has anything to do with it but I think it's the culprit. It seems to be a fairly common problem.
  15. #1165
    Jun 2009
    Budapest, Hungary
    it happened a few times yesterday when I was tweaking the cpunb
    1090T | CH4F | HIS HD5850 | TT EvoBlue 750W | TT Spedo Advance | CM Aquagate Max | Samsung S27A350
  16. #1166
    NooB MOD
    Jan 2006
    South Africa
    Quote Originally Posted by TheBlueChanell View Post
    I have never seen it, but the latest BIOS I've used is 1.6
    Perhaps try an older one?
  17. #1167
    Apr 2003
    Denmark
    I have the hyper transport sync flood error when i raise the nb but mostly when i bench all my 4 HD5770 cards in quad cf
    The man with the littel Barebone!
    And proud Crew of!!!
    Octeamdenmark.com
    Shuttle SX38P2Pro Barebone E8600cpu and HD4870X2 gfx and 2gig Crusial Ballistix PC8500 Cl5 and 2x150gig Raptor in raid 0 and 1x750 gig seagate
    Msi 790FX-GD70 Mobo Amd 955-965 PHII cpus and 2gig Crucial value PC10600@800mhz 7-5-5-15 1T
    And 4x500GB Seagate 7200.12 in raid0
    4xHD5770 in CFQ.
    [SIGPIC][/SIGPIC]
  18. #1168
    Mar 2006
    Arcadia, CA
    I am new to this board. Just an interesting observation. I have to flash to the 1.70 bios in order to have it work correctly with a 965 X4 black edition (C3 stepping). I tried 1.1 (shipped with the board) and 1.6b3, I can get into the bios setup but I wasn't able to boot from an USB or from an optical drive. They both hang after auto-detecting USB mass storage devices during POST. The LED shows the "b1" code and it just stays there. I have to use M-Flash to update the bios to 1.70 from an USB drive. Everything seems to work now. Does anyone encounter the same issue?
    Intel Xeon X5650
    ASUS Sabertooth X58
    3 x 2 Gb G.Skill PC3-12800
    MSI GTX 780Ti Gaming 3 Gb
    Seasonic X850
    Corsair 750D
    Heatkiller 3.0/D5 & EK Top/Alphacool UT60 240
  19. #1169
    Xtreme Mentor
    May 2008
    cleveland ohio
    Quote Originally Posted by Riska View Post
    have you tried raising both ?
    that seems really odd
    HAVE NO FEAR!
    "AMD fallen angel"
    Quote Originally Posted by Gamekiller View Post
    You didn't get the memo? 1 hour 'Fugger time' is equal to 12 hours of regular time.
  20. #1170
    May 2009
    Some of the bios's had the HT syn flood issue...I would suggest you use CPU - NB Volts rather than the VDDC to raise voltages and then check....
  21. #1171
    Jul 2007
    I'm really like this board. I've found out that dominator gt's, which I rouged from my i7 setup, seem to be very light on the IMC. I can hit cas6 on these things with NB @ 3300mhz and CPU @ 4600mhz. Also cas6 with NB @ 2800mhz and CPU @ 4700mhz.
  22. #1172
    Jul 2009
    Beyond the Gate
    I also started getting the HT Sync Flood error all of a sudden, even though I've been running my system at 3.6GHz CPU, 2.4GHz NB, 2.4GHz HT, (all on stock Volts) for months without a problem.
    It's either the 1.7 BIOS or a driver issue from my 5850 that has definitely been the cause, because I added the 5850 and updated the BIOS the same day.
    TheBlueChanell, do you use a 5000 series ATI GPU too?
    Is there anyone that is getting this error after updating to BIOS 1.7, but is not using the Radeon 5000 series graphics card?
    EDIT: I did drop my RAM volts to 1.5V from the mobo's default 1.6V because my RAM is rated to use 1.5V, but I read that the RAM voltage being too low is a possible cause of this error. Goona try put it back up to Auto (1.6V) and see how it goes then report back.
  23. #1173
    Apr 2007
    California
    I think the flood issue is a bug in 1.7. I went back to 1.6 and haven't run into the same issue.
    Intel® Core™ i7 920@200x21=4.2Ghz w/1.312v HT on
    Asus P6TD Deluxe
    H2O by Petra's Tech CoolKit Elite Rev.2 w/D-TEK FuZion V2
    EVGA GTX 580
    OCZ3P1600LV6GK 7-7-7-24-1T 6GB
    OCZ Vertex 2 50Gb in Raid-0
    Super Talent UltraDriveGX 128Gb
    WD VelociRaptor 300
    Corsair HX850W
    Windows 7 Professional 64
    AMD Phenom™ II X6 1090T BE @ 4131Mhz(243x17)
    Asus Crosshair IV Formula
  24. #1174
    May 2009
    I was trying to OC past 4.2 and computer hung. So I switched it off and cleared cmos, but now it just gets stuck with code FF and then nothing happens. I have removed the battery and unplugged it for 15 minutes but that didn't work either. So have done it again and have left it for now. There is no display so I am wondering if there is anything else I can do. I see the blue cpu vid lights are all on, so looks like its stuck. What do u guys recommend
  25. #1175
    Jun 2009
    just gonna throw in my experience with bios ver 1.7 gave me tons of boot up problems @first, did a little tweaking got it to boot up in to win 7 but after bouit 20 secs after logging into user acct windows would lock up completely after it was done loading up. went back to ver 1.6 and all is fine now thank god!@
    ffs msi if you see this fix 1.7 it is garbage!!!!!
    -phenom II x4 955 BE 3.7 GHz
    -msi 790fx-gd70 bios ver 1.6
    -8 GB - OCZ platinum amd edition 1600 MHz @ 7-7-7-24-28-1T@1.72 v - OCZ3P1600LVAM4GK
    -msi radeon 4890 oc edition 955/1150
    -2x western digital caviar black 640GB
    -kingwin mach 1 1220 w psu
    -coolermaster cm690 nvidia edition (LOL)
