Hi everyone, on this weekend i tried to play a bit with AMD Phenom II 940 compare with Core 2 Extreme QX9770 for performance per MHz between it at same clock so clock speed is i test at 4.0GHz and run 3DMark for compare, ok let to see what happen from it
AMD System...
Phenom II 940@4.0GHz
ASUS M4A79 Deluxe
4x Crucial Ballistix PC8500@1066C5-5-5-15
ASUS HD4870X2 Top@832/1000MHz
WD Raptor
GIGABYTE ODIN 1.2kW
Vista SP1
Benching results...
2k3
2k5
2k6
Vantage
Intel System...
Intel QX9770@4.0GHz
Biostar TP45 HP
4x Crucial Ballistix PC8500@1000C4-4-4-12
WD Raptor
GIGABYTE ODIN 1.2kW
Vista SP1
Benching results...
2k3
2k5
2k6
Vantage
Thank you !![]()
