Results 1 to 7 of 7
Thread: Windows 7: "System Interrupt Controller"?
    Oct 2006
    Chicago 'burbs
    Does anyone have a clue as to what these errors represent?
    After OS install, ran most recent X58 chipset installation, graphic drivers, etc.
    TT Armor|Asus Rampage II Extreme|i7 940| 2X EVGA GTX 295 Quad SLI|X-FI Titanium Fatal1ty Pro|Feser TFC480 4x104cfm 38mm Panaflows Swiftech GTZ MCP655 MCW-NBMAX|3x2g Corsair Dominator TR3X6G1600C8D|Silverstone Olympia 1000w PSU|Logitech G-15|1x 150g Raptor, 3x320 Seagate 7200.10 sata|2xLite-On 20xDVD/RW sata|37" Viewsonic LCDTV/HDMI-DVI (serious gaming)|Samsung 244T (semi-serious gaming)
    Camera Stuff:
    Rick
    D800,D3,D300,F6,80-400mm G VRII/ 70-200mm f/2.8 VRII/70-300mm VR/24-85mm f/3.5-4.5G/50mm f/1.4G,/85mm f/1.4D AF/58mm Voigtlander f/1.4/
    24-70mm f/2.8/200mm f/4D Micro/400mm f/2.8 VRII/300mm f/2.8 VRII/500mm f/4.0 VR
    Flash:SB-400/SB-600/SB 900
    TC's: Nikkor, 1.4x 1.7x 2.0x III.
    Support: Manfrotto 680B monopod Gitzo GT5541LS tripod Induro GHB2 gimbal RRS MH-01 head.
    Sep 2003
    St. Louis, MO USA
    I think those are the SMBus drivers from Intel. I have the same issue on my X58 P6T Deluxe, W7 won't let me download them from the install cd. Things seem to be working OK though and haven't went to the Intel site to download and install them with Troubleshoot Compatibility (right click the downloaded drivers).
    The Money Trap = Intel i7 3930K | Corsair H100 push/pull fans | ASUS Rampage IV Extreme | 16GB (4 x 4GB) G.Skill DDR3 2133 9-11-10 CR1 | 2 x EVGA 680 SC+ Signature SLI | 256GB Samsung 830 SSD - OS, 256GB Crucial M4 SSD - Games - backup WD HDDs | Klipsch ProMedia | Cooler Master HAF 932 | Antec TPQ-1200w | Dell U2711 2560 x 1440 27" | Win 7 Ultimate 64-bit | APC RS1500
    Oct 2006
    Chicago 'burbs
    Quote Originally Posted by nuclearjock View Post
    Solved!!!!
    For my Rampage II extreme,
    1. Download Intel X58 chipset utility from Asus website (zip format)
    2. Unpack (extract) to a vacant folder.
    3. In device manager, right click on other devices showing error and direct search to folder created in step 2.
    issues will be resolved.
    Camera Stuff:
    Rick
    Dec 2002
    Solved!!!!
    thx solved here too.
    4670k 4.6ghz 1.22v watercooled CPU/GPU - Asus Z87-A - 290 1155mhz/1250mhz - Kingston Hyper Blu 8gb -crucial 128gb ssd - EyeFunity 5040x1050 120hz - CM atcs840 - Corsair 750w -sennheiser hd600 headphones - Asus essence stx - G400 and steelseries 6v2 -windows 8 Pro 64bit Best OS used - - 9500p 3dmark11 (one of the 26% that isnt confused on xtreme forums)
    Oct 2006
    35n28, 97w31
    Solved!!!!
    This worked for my P6T Deluxe. Thanks!
    | Intel Core i7-2600K | ASRock P67 EXTREME4 GEN3 | G.SKILL Sniper Series 8GB (2 x 4GB) DDR3 1866 | EVGA GTS 450 |
    | Swiftech APOGEE Drive II CPU Waterblock with Integrated Pump | XSPC RX360 | Swiftech MCP655-B Pump | XSPC Dual 5.25in. Bay Reservoir |
    | Thermaltake 850W PSU | NZXT SWITCH 810 | Windows 7 64-bit |
    [SIGPIC][/SIGPIC]
    Feb 2006
    Richmond, VA
    just as an FYI, and because this thread helped me figure out the problem...
    same symptoms, but on an MSI x58 platinum board. Fresh install of Windows 7 x64 beta. Downloaded latest MSI chipset, tried to point to driver folder, nada. Downloaded Asus Rampage II Extreme chipset drivers, problem solved.
    Feb 2009
    Here also fixed on a msi eclipse motherboard.
