Hi All,
I just got my board up & running & as there wasn't a thread already going I thought I'd make one.
Fell free to chip in
CN
DFI Lanparty UT P45-T2RS
Click To Enlarge
BIOS screen shots [1007]Code:Specification: CPU LGA 775 socket for: - Intel® Core2 Quad and Intel® Core2 Duo Supports Intel Enhanced Memory 64 Technology (EMT64T) Supports Enhanced Intel SpeedStep Technology (EIST) Supports Intel Hyper-Threading Technology Supports 1333/1066/800MHz FSB Chipset Intel® chipset - Northbridge: Intel® P45 Express chipset Intel® Fast Memory Access technology - Southbridge: Intel® ICH10R System Memory Four 240-pin DDR2 DIMM sockets Supports DDR2 667/800/1066 MHz Delivers up to 12.8Gb/s bandwidth Supports dual channel (128-bit wide) memory interface Supports up to 8GB system memory Supports unbuffered x8 and x16 DIMMs Expansion Slots 2 PCI Express (Gen 2) x16 slots (PCIE 1 and PCIE 3) - 2-way CrossFire at x8/x8 bandwidth - 2-way CrossFire + Physics at x8/x8/x4 bandwidth 1 PCI Express x1 slot (PCIE 2) 1 PCI Express x4 slot (PCIE 4) 3 PCI slots BIOS Award BIOS 8Mbit SPI flash memory CMOS Reloaded Audio Bernstein audio module - Realtek ALC885 8-channel High Definition Audio CODEC - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector DAC SNR/ADC SNR of 106dB/101dB Full-rate lossless content protection technology LAN Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards Storage Intel ICH10R chip - Intel Matrix Storage technology - Supports up to 6 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1, RAID 0+1 and RAID 5 JMicron JMB363 PCI Express to SATA and PATA host controller - Supports up to 2 UltraDMA 100Mbps IDE devices - Supports 2 SATA devices - SATA speed up to 3Gb/s - RAID 0 and RAID 1 IEEE 1394 VIA VT6307 Supports two 100/200/400 Mb/sec ports Rear Panel I/O 1 Mini-DIN-6 PS/2 mouse port 1 Mini-DIN-6 PS/2 keyboard port 1 IEEE 1394 port 6 USB 2.0/1.1 ports 2 RJ45 LAN ports Internal I/O 3 connectors for 6 additional external USB 2.0 ports 1 connector for an external COM port 1 connector for an IEEE 1394 port 1 connector for the Bernstein audio module 1 IrDA connector 1 CIR connector 8 Serial ATA connectors 1 40-pin IDE connector 1 floppy connector 1 24-pin ATX power connector 1 8-pin 12V power connector 2 4-pin 5V/12V power connectors (FDD type) 1 front panel connector 6 fan connectors 1 diagnostic LED EZ touch switches (power switch and reset switch) Power Management ACPI and OS Directed Power Management ACPI STR (Suspend to RAM) function Wake-On-PS/2 / Wake-On-USB Keyboard/Mouse Wake-On-LAN and Wake-On-Ring RTC timer to power-on the system AC power failure recovery Hardware Monitor Monitors CPU/system/Northbridge temperature and overheat alarm Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages Monitors the speed of the cooling fans CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat PCB 6 layers, ATX form factor; 24.5cm (9.64") x 30.5cm (12")
1: Overview CMOS Setup, 2: STD CMOS Features, 3: Advanced BIOS Features 1, 4: Advanced BIOS Features 2, 5: Advanced Chipset Features.
6: Integrated Periferals, 7: Power Management Setup, 8: PnP & PCI Configuration1, 9: PC Health Status, 10: Genie BIOS Setting 1.
11: Genie BIOS Setting 2, 12: CPU Features, 13: DRAM Timing 1, 14: Clock Setting Fine Delay 1, 15: Clock Setting Fine Delay 2
16: Dram Timing 2, 17: Voltage Setting
Downloads
Manual
dfi.com.tw Click Here
BIOS
dfi.com.tw 1007 BIOS Click Here
Beta BIOS
Posted by namegt 1028 BIOS Click Here
dfi.com.tw 1212 BIOS Click Here
dfi.com.tw 0112 BIOS Click Here
Product Information, Recommended Memory, CPU Compatability,Drivers & Apps
Reviews
Clunk.org Click Here
OCDB (Over Clock Data Base) Post up your stable clocks.
Kitfit: E8600 @ 5GHZ DDR1200 10H Prime Blend Stable Post 63 Click Here Link to Settings Click Here
CN: E8500 @ 4.5GHZ DDR1186 9.5H Prime Blend Stable Post 63 Click Here
CN: Q9650 @ 4350MHZ DDR1160 9.25H Prime Blend Stable Post 277 Click Here
CN: Q9650 @ 4.3GHZ DDR1150 9.5H Prime Blend Stable Post 257 Click Here
PolRoger: E8600 @ 4.25GHZ DDR1218 2H OCCT Stable Post 45 Click Here
SOXX: Q9550 @ 4.2GHZ 3H Prime Stable Post 395 Click Here
CN: Q9650 @ 4.2GHZ DDR1166 8H Prime Blend Stable Post 230 Click Here
Peter Burg: Q9550 @ 4.0GHZ 1H Prime Small Stable Post 194 Click Here
SOXX: Q9550 @ 4.0GHZ 2.5H Prime Stable Post 328 Click Here
prostoman: QX9650 @ 4.0GHZ 13H Prime Stable Post 278 Click Here
FSB Race TrackCode:andrewmodus: Q9650 @ 4.0GHZ 10H Prime Blend Stable Post 370 Click Here Thule: Q9550 @ 3958MHZ 3H Prime Stable Post 276 Click Here
Dual Core
CN: 625 E8500 Click Here
namegt: 600 E8400 Click Here
kitfit1: 563 E8600 Click Here
PolRoger: 500 E8600 Click Here
Quad Core
Super PI Race Track
1M
namegt: E8400 556 X 9 9.390 seconds 1M Click Here
prostoman: E8600 500 X 9 9.499 seconds 1M Click Here
CN: E8500 600 X 8 9.687 seconds 1M Click Here
namegt: E8400 534 X 9 9.734 seconds 1M Click Here
prostoman: QX9650 392 X 12 9.953 seconds 1M Click Here
32M
namegt: E8400 556 X 9 10m 19.781 seconds 32M Click Here
roedzzz: E8600 600 X 7.5 10m 25.473 seconds 32M Click Here
Everest Cache & Memory Benchmarks
473 x 9.5, 592 mem Read: 10480 Latency: 48.5ns Click Here
520 x 8, 624 mem Read: 10814 Latency: 47.0ns Click Here
530 x 8, 636 mem Read: 11019 Latency: 46.2ns Click Here
540 x 8, 648 mem Read: 11219 Latency: 45.4ns Click Here
550 x 8, 660 mem Read: 11428 Latency: 44.4ns Click Here
560 x 8, 672 mem Read: 11662 Latency: 44.0ns Click Here
560 x 9.5, 672 mem Read: 11805 Latency: 43.4ns Click Here
562 x 9.5, 675 mem Read: 11925 Latency: 42.5ns Click Here
600 x 8 600 mem Read: 11204 Latency: 46.2ns Click Here
Smartguardian Skin (Use with DFI DK non plus Smartguardian) Thanks to DJ Sub for the Background
Dual Core SG Skin Click Here
