http://www.zipzoomfly.com/jsp/Produc...dlist=celebros
^ordering as soon as my E8400/P5Q-Deluxe/Gskill sells.![]()
Main: 900D - Prime 1000T - Asus Crosshair VI Extreme - R7 1700X @ 4.0ghz - RX Vega 64? - 32GB DDR4 3466 - 1TB 960 Pro -
--- XSPC AX360 x3 - HK IV Pro - HK RX480 - HK 200 D5 - BP Compression ---
HTPC: 250D - Prime 850T - Gigabyte G1 ITX - i7 6700K @ 4.5ghz - GTX 1080 Ti - 16GB 3200 - 1TB 960 Pro -
--- ST30 x UT60 - Kyros HF - KryoGraphics 1080 - HK100 DDC - Monsoon Compression ---
HV01: Define XL R2 - Prime 1200P - Asus Zenith Extreme - TR 1950X - RX580CF - 128GB DDR4 ECC - 512GB 960P - 4x 2TB RE
HV02: Node 804 - Prime 850T - SuperMicro X1SSH - E3-1230 v6 - Vega FE - 64GB ECC - 512GB 960 Pro - 4x 6TB Gold -
any difference between this quad compare to the upcoming deneb? sorry i haven't been keeping up with amd's quad cores. i'm itching to go quad cores. i can't believe i've been holding out this long. i got a dfi lan party dark 790fx board. thanks.
I need this thing to hit Newegg.com so I can use my Preferred Account. Also I'm torn between this and the Athlon X2 GE-6600 (whenever it comes out) because the plan is to upgrade to a Deneb down the line. Either way, my bet is that this CPU hits Newegg on Wednesday. They're always a couple of days behind it seems.
so ur saying 45nm is lower icp and higher power usage? that don't sound good. or did you mean the other way around?
mobo: strix b350f
gpu: rx580 1366/2000
cpu: ryzen 1700 @ 3.8ghz
ram: 32 gb gskill 2400 @ 3000
psu: coarsair 1kw
hdd's: samsung 500gb ssd 1tb & 3tb hdd
I am waiting too for 45nm ,but i will buy a 9950 (125watt) at end September to compare to the One i have @140watt.. I think it just may be a surprize Overclockable 65nm Chip . Hope my gut feeling is correct. I cant stand the wait
Patience goes a long way ,at least for me, ATM.
AMD Phenom II 1090T @ 4GHz Asus Crosshair IV
HD6970
LSI Megaraid 9260-4i 4xMomentus XT
OCZ Vertex 3@SB850
8 gig Patriot Viper 7-7-7-24 T1
Swiftech Watercooling
Filco Majestouch 2
Zowie EC1
The processor's voltage range is listed as x to 1.30V. If this processor runs at 1.30V like our 9850s and current 9950s, it can't be a 125W unless they actually redesigned the core. I doubt that happened. I suspect a mislabel (actually being 140W) or a bad voltage spec provided (< 1.30V stated).
Particle's First Rule of Online Technical Discussion:
As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
Rule 1A:
Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
Rule 2:
When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
Rule 2A:
When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
Rule 3:
When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
Random Tip o' the Whatever
You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
Newegg have the M3A79-T Deluxe Now for Cheaper
http://www.newegg.com/Product/Produc...82E16813131339
ASUS P6T7 WS Supercomputer
Intel Core i7 920 2.66GHz Batch 3849A925
ZALMAN CNPS9900LED 120mm
CORSAIR DOMINATOR 6GB DDR3-1600 (3 x 2GB)
ASUS ENGTX260 MATRIX
500x1 - 4x160 -1 x 750GB HD's
COOLERMASTER ATCS 840 Black
Antec Signature SG850 850W PSU
On Board Sound
SAMSUNG T260 Rose-Black 25.5"
Wndows 7 RC
in the features
140W CPU Support – Enhanced Power Design for future CPU upgrade!
100% Japan-made Solid Cap (5000hrs VRM) – Longer Life & Higher Efficiency!
does that mean the board will last for 208 days![]()
Amd Nvidia/Ati -3dmark06 scorebord revisted
asus L1N64-ws or /b depending on bios chip
4x1gig 8500 gkill bpk
2x opteron 8224 @ 3.8ghz
http://www.xtremesystems.org/forums/...&postcount=236
vga= 8800gt
winxp pro
custom chiller -31 water
2x dtek fuzions
bix3-with x3panaflo hi output
antec 850 quattro
heat under msimax abitmax and dfimax
No ,,its suppose to be new lower TDP and Silocon stepping all together.
If that New DFI/FX dosnt show by the end of the Month ,,i may have to get the M3A79-T instead or 78-T.. I just hope Asus Bioses are better this time around than the First Fx's.
Is there any difference between the current Gen and this chips performance, does it overclock any better...
I have one of the older ones in the mail, wondering should I return for one of these![]()
Coolermaster Cosmos S
BenQ 241w
Asus Chrosshair II
OCZ Reaper HPC Edition 4GB
Gigabyte Oden 1200w psu
AMD Phenom 9950BLK@ 3000
Swiftech MCP355, D-TEK FuZion v2
Tygon B-44-4x,XSPC Dual Bay Res.
SAMSUNG Spinpoint F1 1TB
Radeon HD 4870 X2
Black Ice GT Stealth 360 XFlow
Bada Bing Bada Boom
I'm hoping this 125w 9950 will give us better overclocks than the 140w Variant. I'm ordering my M3A79-T tonight. I may order a X2 5400+ to give me something to play with while I wait for the 9950 125w/X2 GE-6600.
What designators in the serial let you know this is a 125 W vice a 140 W?
Must be the X
125W = HD995Z X AGHBOX
140w = HD995Z F AGHBOX
This must be a point of re-entry to AMD for me![]()
Probly still have to deal with cold bug, but its ok
Which mobo do you guys recommend?
Thanks for your help![]()
New stepping eh? That's good news.
Rule 1A:
Rule 2:
Rule 2A:
Rule 3:
the 9950 is the same as the 9850 besides 100mhz... I have noticed on average it OC's better and will require usaully hevy v's to do so.. which results in a Higher TDP...My 9850 ran 2.9 solid and nothing else would work 100% stable regaurdless of v's until the SB750. The 9950 does 200mhz more and needs mor v's to do it even on the Saphire 780g board I have. I have ran both.. same stock v-core same temps etc.. this new chip must have a revison changed or something.. or it is just to stop scaring people away from them. 125w sounds better and 140 has been a thing everyone complains about with the 9950. If someone can prove me wrong please do.. cause I am confused why it is higfher then the 9850 if I am not correct.
~1~
AMD Ryzen 9 3900X
GigaByte X570 AORUS LITE
Trident-Z 3200 CL14 16GB
AMD Radeon VII
~2~
AMD Ryzen ThreadRipper 2950x
Asus Prime X399-A
GSkill Flare-X 3200mhz, CAS14, 64GB
AMD RX 5700 XT
No ,, I think the New 9950 (125watt) helped pave a new path to get 45nm faster..Personally I think the new 9950 was a pre test bed for the New 2.6 45nm AM2+ so well be getting a 125watt hotrod 9950 i think..this will prepare us to jump for the 45nm's when they hit the shelves..
I wonder 45nm real soon...Hope so
http://www.digitimes.com/mobos/a20080909PD205.html
Its the same stuff guys... It doesn't make it bad, it's just the nature of CPU tech (as far as I've seen, and my 1st computer was a Commodore Vic20..)
I would predict that early 45nm Denebs will compete quite well with well tuned 65nm X4's... Similar to how Brisbanes kept up with Windsor cores.
The 9950be is actually a pretty good chip... Hopefully Deneb will be able to beat it in the hands of a good tweaker, but it will still need a little time to mature.
I hope I'm wrong, but if history repeats itself (and I personally think it will), I wouldn't expect miracles from the die shrink/arch changes to Deneb...
I'm sure Deneb will get better with time, but I'm still waiting for Bulldozer.
I have no doubt that AMD can come back with a badazz chip similar to the X2, but I really don't think Deneb is what we're waiting for. It will keep them in the hunt, but it won't be the Intel killer we all want...![]()
AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
First Computer: Commodore Vic 20 (circa 1981).
this IPC change isn't much.
Only the lowly L3 has gotten nothing else really.
Where have 32 way L3 is now 48 wayL3 in deneb.
I think it's not going anywhere with low 2 way L1 cache then.
Need 8 way L1 cache a boosted 48way L2 can keep L3 48 way too.
Add me in 16 sse1,2,3,4 pre-core that chip would be obnoxiously huge in in size lol then again we should be able to fit in that 1.5" square right ?
how knows maybe it will evolve like the ATI is going with GPU's....
Deneb will be a welcome change. Higher clocks and higher IPC are always welcome. A 5% average increase is likely to be under what we actually get, and I'd be happy even with that. ANY increase is always a good thing. Let's not shun it because it isn't twice as fast. It's kind of like when people refuse any alternative energy solution because it isn't perfect. Yeah, it's not an image of perfection, but it's an improvement. Why reject it?
Rule 1A:
Rule 2:
Rule 2A:
Rule 3:
