Summer is over now and it is time to start benching again
This summer was really nice, cause I had three OC events. One here with Russian overclockers and AOCC 2008 in Hong Kong and MSI OC event in Amsterdam.
I didn't have much time to prepare before these runs, so they are my base scores for this autumn.
I bought this E8600 from local shop and I wasn't too lucky, but not the most unluckiest either
Setup:
ASUS Rampage Extreme
ASUS 4870X2 CF
Gigabyte/ Club3D 4870 CF
G.Skill DDR3 2GB HZ (6-6-5-15)
Thermaltake Thoughpower 1200W
First I tested, what this setup can do on aircooling. CPU did 4.8GHz with 1.46V (real) and cards ~852/1050
Setup on aircooling:
I got 129K in 03
Then some pictures:
Then we have the scores:
This chip did 1M at 6.4GHz easily:
Aquamark was bit better with dual 4870 than 4870X2 if we look the MHz efficinecy:
01 was fun to watch, (except Nature) with dual 4870. There is no tweaks at all, cause there was no point in that (850/1050 used):
3Dmark03 was nice to test with these new cards. No bugged scores here (850/1050 used):
05 is one of my favorites, but this time I had some troubles with GPU/mem clocks (800/970 used):
I had only 20L of LN2, so I had to make it quick. I had to test all 2D and 3D tests, so there was not too much time to bench one particular benchmark.
Now I will start to tune this setup and try some different cooling for the vgas soon![]()
Thanks for checking this thread!
unless you could share
6.4GHz AM3 benching from wasn't too lucky
