So my computer draws 179w from the wall idle with the 4870 running at 500/900. Here's the thing if I lower it to 100/200 with amd gpu clock tool the idle power draw is 139w (I don't dare go lower, I started getting artefacts at 150mhz memory clock).
Why are the stock 2d clocks so high? Most of the time it just sits there in windows with 0% activity anyway
Without any fan speed adjustments
500/900 = 79c idle
100/200 = 56c idle
VRMs down from 91c to 56c.
So why can't the default 2d clocks be lower in ccc and its stupid 500/800 minimum limit. 40w less is very noticeble...
EDIT/ took a while for the temps to settle
0% GPU fanyet 1000rpm
