Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Foxconn Dreadnought + 3-way GTX 280. Vantage testing begins
Hybrid View
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Hi all!
    I used this weekend to test Foxconn Dreadnought 790i Ultra motherboard and Foxconn GTX 280 graphics cards.
    All didn't go as well as it could have, but I got some first scores out
    Setup:
    QX9650 (5.4GHz, -110c, 1.94V in load)
    Foxconn GTX 280 (3-way SLI) 740/1480/1280 1.3V
    G.Skill F3-12800CL7 2GBHZ (7-6-6-15 1T "safe settings")
    Thermaltake 1200W
    Cooling: Air cooling on vgas and chipset. LN2 on CPU.
    Driver 177.35 + Nvidia PhysX (I hope FM find a way to handle this issue with new hotfix or something )
    Then you have to see some pictures of my current setup:
    Then some scores:
    X 16138 (CPU only 4.8GHz. No need for more MHz)
    http://service.futuremark.com/compare?3dmv=196722
    H 23190 (CPU @ 5.2GHz)
    http://service.futuremark.com/compare?3dmv=203901
    P 32504 ( CPU @ 5.4GHz)
    http://service.futuremark.com/compare?3dmv=204016
    E 77608 (CPU @ 5.4GHz)
    http://service.futuremark.com/compare?3dmv=203996
    Next I will put these cards under cold. I will have some heavy cooling power soon, but first I will test my SLI single stages (1HP each)
    I'm quite satisfied and now I'm hungry for more
    Thank you Peter and Foxconn!!!
    You are as good as your samples are!
    PIfection
    May 2006
    great results mate, looking forward to what you do under cold,
    i guess my plan is similar to yours, ill test each card individually on ln2, then ill target some dual-card benchmarks to get back into the swing of multi gpu pot benching... and then of course onto triple vantage
    Feb 2008
    Sweden
    Under cold you will bring out the beast in these cards.., very nice results.., Congrats so far.., :-)
    Moderator
    Nov 2006
    nice #s m8 ,waiting for colder tests
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    I see FM has approved 177.35 drivers but I dont see the GTX 260/280 visible.
    Good start, passed my scores up.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Quote Originally Posted by youngpro View Post
    Thanks! My problems were CPU related this time. Some HW mods solved my issues. I just need better CPU.
    Quote Originally Posted by fubarswe View Post
    Thank you! I hear these scale pretty well under cold.
    Quote Originally Posted by hiwa View Post
    Thank you! I hope that I can provide them before next week
    Quote Originally Posted by FUGGER View Post
    Yes. They are thinking what to do with 260/280 scores. FM don't want to publish PhysX scores, but they can't show any 260/280 scores in that case. I think they will release new hotfix, where GPU physics is disabled
    More scores are coming!
    Apr 2008
    France
    OT: any idea when the dreadnought will be available in Europe?
    [SIGPIC][/SIGPIC]
    PIfection
    May 2006
    what hw mods u do mate?
    Master of nebulah frost
    Dec 2004
    Dolomites(Italy)
    Nice setup and results
    Battlefield 3: Nachthymnen666
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    PR96 mod. (Permanent vdroop) Then some other mods, whih you have seen in our e-mails. Nothing special. Vdroop should be fixed in next bios release, but I couldn't wait it.
    Quote Originally Posted by nachthymnen View Post
    Thanks! It is nice setup indeed Finally Crysis is fun to play
    Xtreme Guru
    May 2007
    Ace Deuce, Michigan
    my 6600gt spanks those!
    But great job man, that extreme result looks like it should be an 06 score, though I don't think enabling physx will allow for a fair comparison between tri-sli gtx 280 and quadfire 4870x2 (once it comes out) until ati either adopts CUDA or makes something better from HAVOC unless if you only look at the gpu score
    Quote Originally Posted by Hans de Vries View Post
    JF-AMD posting: IPC increases!!!!!!! How many times did I tell you!!!
    terrace215 post: IPC decreases, The more I post the more it decreases.
    until (interrupt by Movieman)
    Regards, Hans
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Quote Originally Posted by AliG View Post
    Nvidia PhysX doesn't help with X scores (Maybe ~50 points). Only E/P likes it a lot and you get few hundred points more in H
    So highly overcloked X scores will be comparable with different graphics cards.
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    1st card under cold
    Today I tested my SLI cooling machine. There is two 1HP compressors in it and they are completely separated.
    First I had to adjust it to handle this really hot card. It couldn't handle it well and evaporator temperature was only -26 in worst cases. (Second test, 2min+, just before the end) Idle was nice -45c (both evap and core)
    There was no problems at all and if this machine could handle load better, benching would be really easy.
    This time I changed PCI-E to 135MHz.
    Few messy and dirty pics (Sorry )
    Quick insulation:
    Setup:
    Best result was done with 1.3Vgpu and 885/1905/1300 speeds.
    These cards scale impressively well under cold
    X 7036 Single GTX 280:
    http://service.futuremark.com/compare?3dmv=205819
    ODOC
    Aug 2006
    Copenhagen - Denmark
    Good work, good to see the gtx280s arrived ...
    I will have an eye on u ...
    PIfection
    May 2006
    sweet im impressed with the pci-e thats what i like to see
    can u pass triple with that?
    Dec 2007
    France
    are the 135MHz for the PCI-e with a SATA hard drive ?
    Jul 2003
    Looking good Pete, what container is that?
    Quote Originally Posted by SF3D View Post
    Really? That seems backwards to me. I suppose thats what I get for not running Vantage
    Next I will put these cards under cold. I will have some heavy cooling power soon.
    Good luck!
  18. #18
    PIfection
    May 2006
    mate i havnt tried x and h yet because of monitor restrctioned, do you NEED to clock down cpu compared to other tests (ie, is it alot heavier on cpu during these tests) or have you just done it because its not requried for maximum score?
    cheers
  19. #19
    Turkey Man
    Mar 2005
    Jakarta (ex-Australia)
    i think its the later youngpro, since the GPU are getting raped so hard they are the bottleneck.
  20. #20
    Xtreme Legend
    Sep 2002
    Finland
    Nice work
    Favourite game: 3DMark
    Work: Muropaketti.com - Finnish hardware site
    Views and opinions about IT industry: Twitter: sampsa_kurri
  21. #21
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Quote Originally Posted by Oliver View Post
    Keep pushing it ( )
    I tested 130MHz with 3-way. so I'm not surprised if it can do 135MHz as well
    Quote Originally Posted by marmott View Post
    Yes it is S-ATA. No problems at all. Nvidia chipsets have been able to do that since 680i.
    Quote Originally Posted by G H Z View Post
    Really? That seems backwards to me. I suppose thats what I get for not running Vantage Good luck!
    It is my own design and it is perfect. I really mean it. Temperatures can be adjusted just the way I like it.
    Pics and story in here:
    http://www.xtremesystems.org/forums/...d.php?t=186131
    Some of you judge vantage too hard Test it and see it yourself
    I have been sick and tired with old benchmarks and CPU bottleneck! If you don't have good contacts or luck in lottery, you will have to forget top places in those benchmarks. No that time is over. H/X presets are pure vga tests, so battle will be more interesting in those presets
    cheers
    In X preset CPU speed is not relevant. That is pure Vga test and you can use air / water on cpu and then just LN2 to your vgas.
    Yes. That is true!
    Quote Originally Posted by Sampsa View Post
    Nice work
    Thanks! Our skulltrail run seems to be quite low now
    Tonight SLI runs on single stages. 14K in X would be sweet. 13K is my goal.
    I will test some older benchmarks too, but those need so much CPU power, that it is not fun without LN2.
  22. #22
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Two cards under cold!
    Today I got these single stages to work little better. Temperatures weren't dropping so much, but I had another problem.
    Condensation --> It was nice day here, but it was raining a little. Because of that, my cards were swimming in the PCI-E slots
    Tomorrow new try with some better insulation. 900/1925/1300 should be doable.
    Here is the only run from today:
    X 11389 (4.2GHz CPU / 850,1850,1300 GTX 280's)
    VGPU = 1.308V on load
    Setup (Sorry about the mess )
  23. #23
    PIfection
    May 2006
    very impressive mate, your 3d benches are impeccable
  24. #24
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Haha.. That is what I would like them to be
    More scores coming today!
  25. #25
    Feb 2005
    Czech Republic
    SF3D : nice scores dude, but i get 23000 at Vantage too, but only with two cards
    ASUS P8Z68-V PRO B3 + Intel i5-2500k @ 5.0 GHz + Noctua NH-D14
    8GB DDR3 Corsair Vengeance XMP (kit 2x 4GB) 1866MHz / Gainward Geforce GTX470 SLI watercooled
    120GB SSD Kingston HyperX (games) / 1x 30GB SSD OCZ Vertex Turbo (system)
    22" LG IPS226V-PN / PSU Fortron AURUM GOLD 700(W) / Cooler Master HAF Tower RC-932
