XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Graphx Vmods
Reply
Old 11-22-2007, 12:02 PM   #1
K404
Xtreme Mentor
K404's Avatar
ATI 3850/3870 Voltmod thread
Updated:
Tested by multiple users and the mods work fine.
Mods are carried out at your own risk. I will not take responsibility for any voltmods gone wrong. No-ones forcing you to mod your cards and invalidate your warranties.
RAM mod: 80K or 100K trimmer connected between the points marked in blue. Some cards appear to have slightly higher default voltage. If so, I recommend using the higher value of trimmer (ie...100K).
Thanks to (in no particular order)
Rumon, Miwo, largon, Kyky, pinto, pitya
optional core voltmod points (thanks to Largon)
__________________
Proudly using
Crucial Ballistix
Xigmatek air
watercooling by XSPC
Originally Posted by T_M View Post
Originally Posted by soundood View Post
you sigged that?
why?
K404 is offline   Reply With Quote
Old 11-22-2007, 12:13 PM   #2
96redformula7
96redformula7's Avatar
Originally Posted by K404 View Post
Post em up here please!
K
You all should be able to control your voltage through software. You just need some applications to be able to do it in the near future.
__________________
HTPC - AMD Regor 240 - 4GB Gskill - AMD HD 5850 - Avermedia Duet - Harman Kardon avr247 - Surround Sound (Infinity Beta 50's, 10's, 360, and ed a2-300) - Samsung 46"
Desktop Powerhouse PC - Gathering dust due to high usage of HTPC as general pc now
96redformula7 is online now   Reply With Quote
Old 11-22-2007, 12:16 PM   #3
hstuehmeyer2000
take a look at this
http://www.overclock.net/ati/261940-...-mod-bios.html
__________________
Asrock A780GMH/128MB
Phenom X3 8450
2x2gb PC2 5300
ASUS 9600gso
Cooler Master Real Power 600w
WD 500gb
WD 80gb
hstuehmeyer2000 is offline   Reply With Quote
Old 11-22-2007, 12:35 PM   #4
K404
Xtreme Mentor
K404's Avatar
I've heard that some versions of ATITool arent holding the settings, plus realtime adjustment mid-bench is always welcome.
Software voltage adjustment is good, but I'll always go for a hardmod that I can control.
If I had the cards, id be looking for the mods myself, but cant get a hold of either May as well hit the ground running when I invest..
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
Old 11-23-2007, 12:10 PM   #5
nFo
nFo's Avatar
Send a message via MSN to nFo
Has the: ATI Radeon 3870 a cold bug ?
I want maybe put a single stage on it.
So, I removed the stock cooler.
Where I need to look on the PCB ?
nFo is offline   Reply With Quote
Old 11-27-2007, 12:05 PM   #6
K404
Xtreme Mentor
K404's Avatar
Hi. The control ICs are on the back of the card, towards the rear. (opposite end to the monitor plugs)
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
Old 11-27-2007, 03:04 PM   #7
Sage
cant wait for this to be up and running
__________________
___________________________
E6400 @ 466x6 2.8Ghz 1.325v
Asus P5B Deluxe Wifi
2 x 1GB DDR667 @ DDR932 2.4v 5 5 5 15
512mb HD3870 @ 865:2600
Sage is offline   Reply With Quote
Old 11-28-2007, 04:14 AM   #8
Cha0s
Cha0s's Avatar
^^ my card comes tomorrow then i try to make some pictures
__________________
MÖP!!!
Cha0s is offline   Reply With Quote
Old 11-28-2007, 05:48 AM   #9
nFo
nFo's Avatar
Ok, sorry I'm bussy with it.
I need more day light.
Old 11-28-2007, 06:04 AM   #10
STEvil
tl;dr
STEvil's Avatar
Send a message via ICQ to STEvil Send a message via MSN to STEvil
volt mod bioses do not work.
__________________
Heatware || 01.01.08; AND 110.9%
Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 14 of 16 (Thats nearly $10,000 in dead motherboards).
All along the watchtower the watchmen watch the eternal return.
Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
LIST OF GAMES WITH ACTIVATION LIMITS/SONY SECUREROM 7: http://knowyourgame.reclaimyourgame....with+SecuROM+7
STEvil is offline   Reply With Quote
Old 11-28-2007, 07:02 AM   #11
kemist
I will be getting one shortly, if no one has posted by then i will put some pics up.
kemist is offline   Reply With Quote
Old 11-28-2007, 08:00 AM   #12
K404
Xtreme Mentor
K404's Avatar
The core uses the uP6201AQ controller- same as whats used on the 2600
For the RAM: the controller is a uP6101BSA. The voltmod, I suspect will be a variable resistor between pins 3 and 6 of this IC, but i dont know what value yet.
Im hunting for more info at the mo.
I cannot confirm or guarantee that anything i say in these posts will work. I suggest no-one tries what I suggest until someone else can confirm it. If I had a card of my own, id try the mods myself first.
close-up pics (taken by Rumon..thanks!):
Also posted in VMod section
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
Old 11-28-2007, 08:31 AM   #13
STEvil
tl;dr
STEvil's Avatar
Carrying this over from the other thread for those who attempt this before more info is acquired, will make it easier
Just for reference, as long as voltage modification points are between ref and ground you can start at a 100k resistor and measure voltage change, then put in a 50k and repeat.. then 25k, 10k, 5k...
When you get one that increases above stock (say from 1.25 to 1.3) then you need to back up one step and thats the best starting point usually.
I use old 3-pin fan connectors to allow fast changing of resistors without having to resolder each one.
__________________
Old 11-28-2007, 08:39 AM   #14
K404
Xtreme Mentor
K404's Avatar
LOL I was gonna suggest that, but seems like a cheats way of doing it
Hey..whatever works though!
For the core...will need someone with a DMM, and the datasheet to get things moving
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
Old 11-28-2007, 11:20 AM   #15
pitya
I found something. Maybe useful, maybe not. It's a Sapphire HD 2600XT GDDR4. Original here :http://www.topmods.net/articles/?id=104
--- Autotranslation from Russian ---
"For food GPU chip meets the marks - uP6201AQ VLF74P. This 24-hnogy (dvadtsatichetyrehnogy) stabilizer diet, which is very difficult to solder to resist, because the legs are very small. But if those resolved so, it is one leg podstroechnogo resistor at 80 kOm to solder to to the 13rd leg stabilizer, and another to land. If someone is afraid of losing a guarantee, it is possible to use a pencil method to resistor R650 (nominal value of 2.43 Ohms)."
pitya is offline   Reply With Quote
Old 11-28-2007, 12:01 PM   #16
nFo
nFo's Avatar
Ok thanks, I can't get sharp foto's.
Old 11-28-2007, 09:56 PM   #17
Timbosan
Timbosan's Avatar
if that pencil mod is the same i would definitely not try it as the resistance is way too low for a pencil mod (2.43 ohms)
Timbosan is offline   Reply With Quote
Old 11-29-2007, 05:45 AM   #18
K404
Xtreme Mentor
K404's Avatar
Scroll up- I think the images in post 12 are fine, "all" we need now is the datasheet for the controller
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
Old 11-29-2007, 07:23 AM   #19
EvilBellyLint
EvilBellyLint's Avatar
was about to post the same. The images taken by Rumon look
sufficiently clear I think.
EBL
EvilBellyLint is offline   Reply With Quote
Old 11-29-2007, 07:58 AM   #20
Rumon
Rumon's Avatar
EBL
If you do not think the images posted by K404 are clear enough you could always grab the actual file itself you can zoom in a fair bit more without losing any image quality
HD3870 PCB 1200DPI (SendSpace)
HD3870 PCB 1200DPI (RapindShare)
been trying to find the data sheet for it but no luck
Rumon is offline   Reply With Quote
Old 11-29-2007, 08:06 AM   #21
Miwo
Miwo's Avatar
Send a message via AIM to Miwo
Hey guys,
I've just obtained the datasheet for the uP6201AQ
http://www.rit.edu/~mkw1084/miwo/387..._03_070829.pdf
__________________
AMD Rig
720BE @ 3.65GHz 1.43v / MSI GD70 / 4GB OCZ Animal DDR3 / vModded 4850 @ 800/1050
Coolermaster CM690 + Z600 Cooler / Corsair 620HX / Dell Perc 5i + 4x32GB JMicron MLC SSD / 1TB WD Black
Intel Rig
E8300 / DX38BT / 4GB DDR3 / HD3850 / 3x 7200.10 Matrix Raid / Sonata III / Earthwatts 500W
Audio / Video
Samsung 37" 1080p LN37A550
Source: HT Omega Claro, Coax out to Denon (multichannel), SPDIF to Zero DAC (stereo)
Receivers: Denon AVR-788, Sony STR-GX900ES
Speakers: KEF IQ3s + KEF Q8S(surround duty)
LFE: Energy S10.3, 2x Aura Pro Bass Shakers mounted on my office chair
Miwo is offline   Reply With Quote
Old 11-29-2007, 08:32 AM   #22
EvilBellyLint
Originally Posted by Miwo View Post
Hey guys,
awesome
Old 11-29-2007, 11:50 AM   #23
largon
Xtreme Guru
largon's Avatar
I don't see why the method for modding a HD2600XT referred in post #15 wouldn't work as we're dealing with the same controller.
Someone with a DMM please measure resistance between the 13th leg and the middle and far-right spot in this pic:
__________________
You were not supposed to see this.
largon is offline   Reply With Quote
Old 11-29-2007, 12:02 PM   #24
kyky
I made measurement with a numerical voltmetre (I afflict use a Français/Anglais translator)
Vgdr4
Vvpu
kyky is offline   Reply With Quote
Old 11-29-2007, 03:18 PM   #25
Sage
1.89v for the RAM and 1.32 GPU.. both sound right to me
god damn id love to get an extra 10% into both of them
__________________
Reply
Tags
3870, voltmod
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
