At last we got the green light, for posting our test results fore the Q 9200 Yorkfield 2.33GHZ. We got a suspision about the Bios on the motherboards are coresing the low oc.
We have used this motherboards
Asus P5K
Asus P5K DLX
With watercooling the max. Fsb was 470x7 stable at the Asus P5K, without
v-moding on the motherboard
With SS unit the max. Fsb was 480x7 stable at the Asus P5K DLX motherboard
Conclusion: if you are able to oc. a Q6600 to 3.6GHZ it will overun a
Q9200 / 2.33GHZ@3.290GHZ
The good about Q9200 are low voltage and high preformance with low MHZ and temp.
