Page 1 of 3 123 LastLast
Results 1 to 25 of 60
Thread: Help with vdimm & vcore mods for ASUS M2N-SLI Deluxe, please.
    Xtreme X.I.P.
    Dec 2003
    Hey guys!
    I would love some help figuring out vdimm & vcore mods and reading points for this board, ASUS M2N-SLI Deluxe (nForce570 SLI, Socket AM2). I know that Shamino already did those for M2N32-SLI Deluxe (nForce590 SLI) but it doesn't seem to be the same
    I have taken few shots of maiboard in question below. Max voltages at this moment are 2.5vdimm (BIOS) and ~1.65vcore (BIOS). I could use some vdimm of 2.7v+
    Xtreme Vmod mod
    Aug 2004
    Cornwall/Newcastle uni, UK
    Can you check the voltages at the 2 points I've marked please
Name:	IMG_8034 (Large).JPG
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    holy jesus.
    look at how close that cap is to the PCI-E lock ? are these morons really that fvk'n stupid holy crap.
    i thought it was bad on my -e premium board
    man no way..
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    Mar 2005
    Spain
    Quote Originally Posted by persivore
    Both points shows vdimm voltage in my M2N-E that has the same layout than M2N SLI. In mine it's 1,96 on the IC and 1,95volts in the inductance...
    Any news ?
    Asus P5K Premium//Intel E6600@3,6ghz//Corsair PC6400C3@500 4-4-4-12 2,2v//8800GTS G92//Audigy 2 ZS//SeaSonic M12 700W & LianLi V2000B
    Xtreme Vmod mod
    Aug 2004
    Can someone check the resistance between the pin I've marked and ground please.
    Mar 2005
    Spain
    There are 512ohms. ( with power off of course )
    Thanks!
    Xtreme Vmod mod
    Aug 2004
    For the Vdimm mod, connect a 20k VR between that pin and ground. Decrease resistance to increase voltage.
    Mar 2005
    Spain
    Thank you very much, ill try it this afternoon or on friday, as soon as i can.
    Xtreme Vmod mod
    Aug 2004
    For the Vcore mod, can you check the resistance between the pin I've marked and ground please.
    Mar 2005
    Spain
    There are 1530ohms
    Sep 2005
    Belgrade, Serbia
    is it important how much W (or maybe current) can handle 20k VR? Or i can use any 20k VR that i can find?
    Sep 2005
    Belgrade, Serbia
    Quote Originally Posted by ^don.k's^
    in my M2N-E
    max voltages in the BIOS are 2.5vdimm and 1.65vcore right? (like M2N-SLI Deluxe)
    Mar 2005
    Spain
    Quote Originally Posted by Misko82
    No, you can use any vr you can find. I use 20-25 turns VR. The vmod just manages voltages, not current ( this remains in to the mosfets i think ), so wattage isnt important.
    Mar 2005
    Spain
    Stock on my M2N-E is just crap. I can just adjust vdimm up to 1,95v and vcore up to 1,62-1,65. If i were able to get 2,5volts to de ram i wouldn do the vmod, yet. Anyway maybe something's wrong with my mobo or so that i can just adjust that voltages, i thought id have the same than m2n sli since they use the same pcb... I'd like to know if we can use m2n-sli bios, but i dont know anyone who can say something about that...
    Regards!
    Xtreme X.I.P.
    Dec 2003
    Sorry persivore, late to the party but I will give you answers from my M2N-SLI Dx. BTW, thanks for help ^don.k's^
    Now, to the answers:
    post #2 --> both are 2.52v (at 2.5vdimm set in BIOS)
    post #5 --> 512ohm
    post #9 --> 1530ohm
    BTW, vcore can be measured at that choke's leg, on the last pic of my initial post. At 1.537v set in BIOS, I get 1.57v from DMM and also 1.57v from BIOS Hardware Monitor.
    I will try vdimm mod next week, persivore! Thanks for that one
    EDIT: I have just added a legend for vcore and vdimm measurements on this mobo.
    Mar 2005
    Spain
    Just did vdimm mod, and it just works perfect, i went up to 3,12v ( yeah, i was really scared when i saw it @multimeter lol ), and got this with my better pair of 8000UL:
    Using 2,8volts.
    Ill post pics tomorrow, as i thought, M2N-E and SLI are the same, in pcb and vmods too.
    Regards!
    Sep 2005
    Belgrade, Serbia
    ^don.k's^ do u have same cold boot, and reset problems like bachus_anonym with his m2n-sli?
    p.s. 3.xx vdimm for ddr2, uf wau .
  18. #18
    Mar 2005
    Spain
    Yes, i cant reboot from windows without shuting down, and saving bios needs some restart, this mobo runs great once you get it running, but, it's hard to get it running lol
    I'll keep testing with vdimm mod this afternoon when i get some free time, i'd like to hit 580 4-3-3
    Regards!
  19. #19
    Xtreme Vmod mod
    Aug 2004
    For the Vcore mod, connect a 50k VR between the pin marked in post #9 and ground. Decrease resistance to increase voltage.
    If the pin on the chip is too small to solder to, could someone post a high res picture of the chip so I can look for an alternative solder point.
  20. #20
    Xtreme X.I.P.
    Dec 2003
    Cool! Thanks! But you're right, those legs are quite tiny. Here's a close-up I managed to snap, without removing a heatsink. Kind of crappy due to bursting flash, but only this way I could get the traces to show up on a pic.
    EDIT: It looks like that soldering pad I marked might be the best choice for an alternative for Pin7, am I correct?
  21. #21
    Mar 2005
    Spain
    Tomorrow i'll be in the work, i hope i can find an alternative point for #8 pin. Also ill do pics of my mod, and more tests Ill keep this updated
    Regards!
  22. #22
    Mar 2005
    Spain
    Im here again
    Vcore mod:
    THIS DOESNT SEEM TO WORK! I HAVENT TESTED MYSELF! Sorry( just vcore mod )
    Vdimm mod:
    My vdimm mod:
    Regards!
  23. #23
    Sep 2005
    Belgrade, Serbia
    This board is maybe the best one for AM2 when moded, layout is perfect, memory goes in 1&3, in other mobos is 1&2 (Abit, Epox..... not so good for cooling the memory), cooling of SouthBridge is perfect, location of sata, ide, flopy, power is perfect, the colour of board is beautiful, everything is perfect . Damn DFI what are u waitnig for..... until Asus rocks, can't wait to get one, i can't get it it in my country jet. I hope that new BIOS will resolve cold boot and reset problems, and maybe some extra oc features or higher HTT.
  24. #24
    Mar 2005
    Spain
    Yes, once moded, i love this board Would be nice more voltage regulation but for the cheap it is, isnt bad at all...
  25. #25
    Jul 2006
    Can anyone comment the chipset temperature, especially when overclocked? I've read several posts on asus forums where they said it gets too hot to touch. Thanks.
