I need to get a copy of the bios's for an asus top 4870x2. if anyone has them please let me know.
If you can wait can i send you them tomorrow
OCTeamDenmark Crew - Cooled and sponsored by CoolerKit.dk
Can you send them to me too?
Or upload them so everyone can get them?![]()
- Gigabyte P67-UD4 | 2500K @ 4.8GHz 1.4v | 8GB G.Skill Eco 1600MHz CL7 1.35v|
- 4870X2 @ 800MHz/1000MHz | Corsair HX620W | Antec P180 | ~14TB Storage | 2 x Intel 80GB G2 in Raid 0 |
- Canon EOS 350D | Canon EF-S 18-55mm+Canon EF 55-200mm | Apple iPhone 3G 16GB |
yes, please do... i know a ton of people that want them.
is Asuses TOP bios compatible with other, eg. Sapphire card ?
OC-Lab.si!!
olso you can send to me the bios!!
thanks
An upload link would most gratefully received, thanks.
I would love to recieved it also, and i have Sapphire also , can i use this BIOS with sapphire?
you can flash most any bios from the same card to another card thats the same.... IE: VT 4870x2 <---> Asus 4870x2. the cards are the same just different bios's with different settings.
I have this card..but I dont know what different TOP with non TOP
and this bios :
http://rapidshare.com/files/141643910/R700_1.bin.html
http://rapidshare.com/files/141644021/R700_2.bin.html
thanks hazzan as fitseries3 says above ( thumbs up for starting the thread) but the bios you have uploaded is not right for the x2 use gpuz to save both the master bios and the slave bios and re upload them if you can , the bios looks to me like a normal 4870 asus top bios rather than x2 and as fits says above higher clock speed and in overdrive the max value you can set is 900 core instead of 800 core
the x2 has 2 bios's. make sure to get both of them
the asus top card has clocks of 825/1000 i believe.
how did you go about getting them saved from the card? im not saying you are inexperienced... just wanting to make sure everything is good to go before i flash my card.
right to save anybody else some time , flashed the bios these bios has to be forced flash as the SSID of the card is different but works a ok but overdrive limit is the same 800 on core so not much point flashing to it but i'd like to thank Hazzan for posting the bios and fitseries for starting the thread
Sorry, itīs my eyes it wrong with![]()
still looking. thanks for trying though Hazzan. i appreciate it. we will find it soon.![]()
Oh no! You can't find the TOP bios via XS, what now?![]()
Where courage, motivation and ignorance meet, a persistent idiot awakens.
